nicodem
Do the custom tips and you will be happy. They are worth it...
Nice, I actually think I have the blue and red (color around the stem) Spinfits somewhere around here. I've had great luck with the white triple flanges (with the smallest flange cut off - is that what you refer as double flange?) on all my IEMs but will give the Spinfits a fair shake as well.
Just jumped on one of these. RIP wallet.
Nice, white Santa (Fedex) delivered these today. I'm actually listening to them now...
Don't cheap out on the DAC, you've bought $2K headphones after all. I tried pairing it with a Fiio M6 because the size fit so well with the KSE1200 amp, and although Fiio usually does a great job with their devices, when I switched to the Mojo or Micro iDSD BL it was another level. Noticeably elevated the experience. I paid so much for these headphones, hell if I'm not gonna get my moneys worth out of them. Otherwise I would've just stuck with my SE846.
And?
Hey there, could I request for listening comparisons between the Mojo & Micro BL?
Sure. Mojo sounds a touch warmer, more musical, and smoother overall. Micro BL I would say is crisper, sharper with details, and richer treble. The thing I've always disliked about the Mojo is it sounds noticeably confined and not as open/full as some like the Micro BL. But its finessed, super clean, and non-fatiguing sound has kept me from letting it go. Hope this helps.
Yeah, my lack of knowledge involving voltage bias. I noticed the kse and Stax srm-d10 both having the same max output voltage of 200v and that's all.
I decided not to go with the kse for now. Amazing for acoustics, but felt it lacked the body, sounded bit too lean for many others types of music. Edit: listening with Westone Star silicone tips, not foam.
Listening to u12t now, not sure i'll keep them.
