bosiemoncrieff
So I can no longer use KSE1500 on the go because the Lightning to Micro cable I was using has suffered too much stress and now the Micro port has bent too far to deliver data, apparently. The placement of the data/charging port on the bottom makes a lot of sense for desktop use, when the data is expected to come out of a laptop port and into the DAC, but it makes no sense for mobile use, with the cable having to make a U at the bottom of one's pocket.
Should I...
(1) Chuck the KSE1500 in the trash
(2) Only listen w/ line in
(3) Buy a new $40 cable from moon audio because "hey it lasted a year" and try to treat it gentler this time
(4) #3, but get one of these to take the stress off https://www.amazon.com/Ksmile®-Right-Degree-Female-Adapters/dp/B01C6031MA/
(5) #3, but get one of these to do the above https://www.amazon.com/4433265-Micro-B-Extension-Syncing-Charging/dp/B00W6URQPE/
Should I...
