bflat
Ok I just tried with my own 1Z to pair with the KSE1200.
If I go below 80 (of 120) on the 1Z on low gain and use more of the KSA1200 amp (90% of the volume pod) with -10dB padding to get to my listening volume, then vocals exhibits a bit of sibilance and the overall sound is drier, probably due to the KSA1200 reaching/near it's amplification limit. The sweet spot is at 90 on the 1Z, and the KSA1200 amp volume pod still gives me about 50 degrees of turns before it max out. I'm thinking that somewhere between about 60-70% of the amp's volume output is where it performs best to my ears and that's where I'll try to aim for from the source output to get it to that level.
Interesting. I'm going to have to revisit the Onkyo DP-S1 then because what you describe is what I heard - dry and sibilant.
Also tried the new double flange Spinfit 240. Bass sounds tighter and not quite a boomy as the regular Spinfits. Isolation and comfort are better for my ears. Also size is different for me - small for 800, med for 240.
