Xinlisupreme
I’m listening Tape and I like transparency sound signature drived by Hiby R5.
Hope sound will improve again
I'm like 80% of the way to buying an r5. I have the tapes. Do you like the pairing? Anything to note about the r5 on its own? I don't want to deviate too much from the Tape discussion, so any thoughts on them together and also maybe a little on the r5 functionality in general? Worth it? I have cayin n5, but the balanced out is broken and it will cost me an arm and a leg to have fixed, plus I hate the laggy interface. I need quick wifi streaming when at home, pocketable for the go, and tidal offline...paired with the Tapes..what do you think?I’m listening Tape and I like transparency sound signature drived by Hiby R5.
Anyone else got the EJ07 yet?
I've had mine for about 2 weeks and I find them to be excellent.
They have the details of the Tape but with a more refined bass and vastly better mids.
They are well balanced across all areas and I guess could be described as more "audiophile" in nature.
All in all I am highly impressed with them, their tuning of all 3 types of drivers is impeccable, hopefully the build quality is better than the Tapes and they will serve me well for a long time.
anyone tried the Tape with the BT20S? it has minimal hiss, which is nice, but the sound becomes more mellow and relaxed compared to wired with my BlueDAC, that i like my Galaxy Buds more than the Tape and BT20S combo. with my other IEMs that i paired with BT20S (OG Kanas, EM2, and T2 Pro) they don't sound very different (if at all) than going wired.
maybe because the estat drivers don't get along with the BT20S?
My 11/11 order of ej07 rebranded set had shipping cancelled after 3 weeks. Seller has said they're sending DHL now rather than cheap post, which means definite customs delay and charges. Ah, the joys of Ali(not-so)Express!
Thanks for your impressions - looking forward to getting them even more now!
It's sad that found out it is not work perfectly with BT20s, the reason I bought ST because I want to combo my BT20s's with it.....
I'm looking for cheaper combo of BT20S + Andromeda sound quality and thought ST can give it...
Make sure to try other sources the dreaded driver fail might have happened.
I use mine with Fostex TM2 (moved on from BT20S). I think the extra power of higher chip gives it a little oomph compare to BT20S. Nothing much though.
Turn on Dolby Atmos with Tape surprisingly doesn't do much. Bring it forward a tiny bit
2 months so far, to be honest, I can hardly tell. The soundstage on BT20S might be a tiny tiny tiny bit smaller, treble still "hot" just not as much, again, I can hardly tell as I'm not that experienced.Interesting combo
How long you have use this ? And which sound part is better, treable or bass ?
