Shanling UA5 - Next step in our portable USB DAC/AMPs
Jan 21, 2022 at 12:37 PM Post #34 of 155
nope, $200 is too much for me. I will probably buy something like shanling ua2 or fiio ka3 instead
Jan 21, 2022 at 5:26 PM Post #36 of 155
Jan 21, 2022 at 7:39 PM Post #37 of 155
I believe that the XDUOO XD05 BAL has a 3.5mm socket that can act as both a coaxial or optical digital input. But those are uncommon.
https://www.audiophonics.fr/en/mobi...th-50-32bit-768khz-dsd512-silver-p-15104.html
Yeah, there are probably some technical difficulties in creating the socket that would do both, but what I meant it cant be said it is different system and not compatible.
It is very comaptible, but one is using light other electronic signal over copper wire. But if you tap coax socket to toslink socket in any receiver / transmitter it will work. Signal is the same standard.
Jan 21, 2022 at 7:59 PM Post #38 of 155
I use UA2 connected to iphone.
Can UA5 be used on iphone like UA2?
Is a lightning cable included? Or can I use the lighning cable for UA2?
UA5 has same support of iOS as UA2. It will work with the same cable.
We do not offer iOS cable.
@Shanling
How many volume steps?
Output impedance (3.5 mm)?
Noise floor rating (3.5 mm)?
99 volume steps
Output specification Single-ended // Balanced
Output impedance 0.8Ω // 1.6Ω
Power 2.1V@32Ω // 2.6V@32Ω
Dynamic range 122 dB // 120 dB
Signal-to-noise 121dB // 116 dB
Channel separation 77dB // 110 dB
Jan 21, 2022 at 8:50 PM Post #39 of 155
Slightly curious that SE measured better than Bal on dynamic range / SNR. If these numbers hold true - not the greatest I have seen on USB dongle but not too shabby either.
Jan 26, 2022 at 8:04 AM Post #41 of 155
i don't like to add more device to maintain battery. i will skip this model. currently use ua2 and love it.
This devices battery is more a buffer they are saying, not something you need to keep topped-off and charged.
Jan 26, 2022 at 7:49 PM Post #42 of 155
You can run it in USB power at all times if you wish.
Jan 26, 2022 at 9:45 PM Post #43 of 155
i will wait for early users reports then.
maybe i only need to charge it once a week. i have too many gadget. hp, tablet, tws, watch..
if i have to add another one, i think i need a secretary LOL (j/k)
