TooPoorForHiFi
Previously known as MidNighTempest
Easiest is to export one first. It will create the correct folder where you can put yours.
Yes, I've tried that. Doesn't seem to play the playlist that I created with mp3tag.
um how do I import playlist? I click on import playlist and it says File not found. Is there a specifc way or place I should put the Playlist Files?
Swapping SD cards – aye a bit of a faff when you just want to pick one up as you’re heading out the door.
I’ve only got a 128GB card and will probably get another. Granted more faff to keep both updated with new file additions, but, I’d have 2 copies so have a sort of backup in case one SD card fails
First world problem and all that…
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
You can get Advanced user manual for Q1: https://drive.google.com/open?id=1X6PHtRWeIwiekYbNfO9ZiQ1BpMi8W0qu
That can help you with lot of settings.
I know database system in MTouch is not ideal for quick swapping cards.
For people that are running on multiple cards, my best recommendations would be to stick with the folder browsing, then you can completely ignore any library scans.
Thanks, I've figured it out. I can't seem to create the playlist if the Main Folder has SUB-Folders in them. E.g I can't create the playlist from the main TOOL Folder that has 6 TOOLS Album folders. I have to go into the tools folder and make 6 playlist.
Also What is the largest Album Art size the player supports? or optimal.
We recommend to go with 500x500 and make sure you don't have progressive jpg. And if you want system to show them in album menu, have them all embedded into tag.
The screen resolution is 360 x 400.That 500x500 doesn't fill up the whole screen and that kinda bothers me. Do you happen to know the actual Size to Fills the whole screen?
That 500x500 doesn't fill up the whole screen and that kinda bothers me. Do you happen to know what Size can Fills up the whole screen?
If you are facing such issue, it's not about the resolution, but there is something else wrong with your pictures.
Do you see this problem on all your files or only on some?
I've rescaled the image to 500x500 & even 360 x 400 without progressive as well as embedded into tag.
The only time I get Full Screen is when the songs / tracks don't have any Album Art cover, The Q1 will use the default cover.
My lock button feature does not seem to be working on any of the settings.I have the Buttons lock setting to on and no matter which of the 3 options i choose it makes no difference the buttons remain unlocked.
The buttons are only locked when the screen is off.
This should be stated in the manual if your not farmiliar how these dap lock buttons work otherwise more people will think the same as me.
Also if the lock button is on and player is in your pocket it could easily become unlocked by catching the power button.
Thank you.
