Shanling Q1 - Retro-Styled Portable Hi-Fi Music Player
Nov 1, 2022 at 11:13 AM Post #529 of 589
Shanling M1S replacing the Q1, coming in December, waiting on price
It basically looks like the M5S and the Q1 had a baby giving berth to the M1S. All the features of the M5S with updated hardware but the same size as the Q1. I am guessing or really hoping it will be in the $200 US range given the improvements. Shanling was true to their word and they did not abandon the MTouch DAP's and looks to be making some nice upgrades though the screen size looks weird and having buttons on the front not a great look. But performance is the most important thing so looking forward to more info to come.
Dec 6, 2022 at 8:20 AM Post #530 of 589
I have enjoyed this little Q1.
I am getting noisy clicking sounds between dsd tracks when feeding it through the Mojo 2. It’s not terribly loud, but irritating enough for me try avoid some of my favourite DSD albums.
I wondered if it may be a glitch in the Q1, but not sure. I don’t get this when I just used my iPhone.. but that may well be downsampling to PCM (the mojo light was uncoloured whether playing DSD or various PCM sampling rates)
I hoped it might be something that could be fixed in a firmware update.
Toggling hapless and DSD output settings didn’t help.
Any ideas?
Dec 6, 2022 at 7:39 PM Post #531 of 589
Any ideas?
The Q1 has been discontinued so I wouldn't hold my breath for a response. Shanling is focusing on the M1S and M0 Pro which are the two new MTouch DAP's coming out supposedly at the end of this month along with all their recently released android DAP's. Might be a good time to sell it and get something else.
Dec 6, 2022 at 7:51 PM Post #532 of 589
Any ideas?
Just to be clear, you are running latest firmware V2.2 and it happens in all three DSD settings? Does the Mojo correctly identify the DSD stream?
Is it just standard DSD64 or higher?
We didn't get our hands on Mojo2 yet, so not something we tested yet.
Dec 7, 2022 at 4:13 AM Post #533 of 589
Thanks for the quick response. I am getting this noise between every DSD/DSF track I play, every time — 64, 128 and 256 DSD. So it’s a consistent issue. The noise is limited to the transition from one track to another — whether I have ‘gapless’ on or off.
As it’s discontinued, I don’t imagine any firmware update would be forthcoming, but I’d be most grateful to get a fix for this 🙏
Jan 21, 2023 at 2:16 PM Post #534 of 589
Anyone knows a workaround how to make the Momentum 3 work with the Q1?
Jan 22, 2023 at 2:23 AM Post #536 of 589
What's the maximum impedance that the Q1 can drive?
It is not a matter of impedance only, one has to factor in the sensitivity of the attached transducer. In fact, sometimes a very low sensitivity may be more problematic to drive than a high impedance load.
Jan 22, 2023 at 4:56 AM Post #537 of 589
I tested the Q1 with my 600-ohm Beyers and it can drive them to medium-high volumes but that is with loud modern rock recordings. If you like to listen to music really loud or listen to more quiet recordings, like classical, jazz or well-mastered stuff not affected by loudness wars with high dynamic range, the Q1 would have problems satisfying those requirements with the 600-ohm DT880 or DT990. I would say it is good for up-to stuff like the HD650 (300 ohm). Planars are a different story though, those often have low both impedance and sensitivity, so the Q1 might have serious trouble with those, but I cannot test that, don't own any planars.
Feb 1, 2023 at 9:05 PM Post #538 of 589
We are aware of this issue, once again Sennheiser being unique with their Bluetooth solutions. So far there is no fix for this.
Feb 2, 2023 at 12:02 PM Post #539 of 589
I found a workaround recently: connecting the Momentum 3 to the Q1 and any other device at the same using bluetooth. Then it works. I can have the Momentums connected to my iPhone and the Q1 at the same time, only play music on the Q1, have the iPhone in silent mode and it works. When I disconnect the Momentum from the iPhone, the current track is able to finish playing OK but the next track is just silence again. The Momentums need to be connected to 2 devices at once all the time to play music from the Q1. The 2nd device does not have to be the iPhone, it works with an audio bluetooth USB dongle as well.
Feb 23, 2023 at 1:20 PM Post #540 of 589
My Q1 freezes whenever I try to play a song with the jack inserted, so it's unusable right now. Does anyone know what could be the cause?
