So no M5s before Christmas is becomming likely?
That would be a bummer!
Did you hear this from musicteck? They've not given any update to me after saying 11.26.... that'd be a bummer. Id almost want to go with the dx120 for now if I can't get this by Christmas.That is not true.
I've asked one dealer. He said that the shipping date has changed(again) to 10/12/18.
And in twitter shanling answered me(16/1118) that they will get m0 and m5s in coming "weeks".
Did you mean "coming months"?
That is not true.
@Shanling - what do you think of existing an 2nd option of Shutdown in the screen instead of pressing 5 second in the wheel.
it could be in the swippe down screen icons.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
SimpleDue to our current move of factory, we are little bit limited in amount of M5s produced in each week, so while some units starts to ship next week(for example Musicteck's), others will ship 1-2 weeks later.
We are quite happy with current solution. Why would you want to add another way to turn off device?
Simple
Because everytime someone as to turn off the device.
It is allways need to wake the device and press the button 5s until the screen appreas to confirm.
A second option, would be more pratical.
The button will be allways needed because off hard reset.
My device as crashed 3 times... the last time was with dad file.
I forced to turned it down as it was unresponsive.
And played the same song to see if the file was corrupted. And nothing whapped.
So it was the device.
So instead of waking up device and holding button for 5 second, you prefer to wake up device, go into slide menu and press software button? Not sure how much practical that would be. Holding down button for X second is standard way how you turn off almost all modern devices.
Regarding crashes, what firmware are you using?
Android OS needs unneccesary heavy resource for the processing chip which should be used for "pure music" instead! I would say just a little bit be patient. May be you are lucky to get the M5s before Xmax!Did you hear this from musicteck? They've not given any update to me after saying 11.26.... that'd be a bummer. Id almost want to go with the dx120 for now if I can't get this by Christmas.
Huh? I don't think it'll be a problem based on what shanling just said, I'm pretty sure I was preorder #1 for musicteck.Android OS needs unneccesary heavy resource for the processing chip which should be used for "pure music" instead! I would say just a little bit be patient. May be you are lucky to get the M5s before Xmax!
Do we actually think sound quality varies alot from dap to dap?
Do we actually think sound quality varies alot from dap to dap? I was listening to the out dated first gen fiio x5 last night through Focal Clears. The sound was very good. And Im no amateur
Not really. The x5 just sounded so good. I cant imagine a huge difference. ( and i own about $4000 worth of equipment, so im no rookie.)Are you comparing X5 to anything specific where you don't hear the difference in sound?
