Hi, just got my Titan M5s yesterday.
After reading the earlier posts, manage to replicate the Ampli relay problems.
The details are as follow:
- Running balanced port
- FW: 2.1
So, everytime i pause tracks, and played it after 30secs of relay clicks, when i played again only the Left channel have sound and muting the Right one. I can eliminate the problem above, by turning on the Auto-Standby setting.
Luckily, when i rolled back to 2.0, the problem is non-existance.
But, there is one problem in BOTH FW. The Library Update keep stuck at No. 2190 out of 3200 songs (90ish GB) in my 128GB Sandisk card with ExFAT...
Please address problems above in the later FW @Shanling , thanks...
Muting only one channel, that's a new...
With problem of scanning, we got few reports of this and every time it seems there is some misbehaving file on card. For example, one user found problem was caused by WAV files bigger than 40MB. Can you check for such files?
So I just bought the Meze 99 Classics and the official Meze 2.5mm balanced cable that was on sale for $50, and both should arrive tomorrow. I just plug the balanced cable into the M5's 2.5mm balanced port and that's all there is to it, right? I'm sorry but I've never had balanced headphones before. The Meze will be my first!![]()
Yes, just connect cable and insert into M5s.
sorry just to check,
can spotify be loaded on this?
There is no Android inside M5s, so unfortunately you can't install other apps.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
