rlw6534
One question I forgot to ask here, which do you prefer between R5 and M3X? Does M3X has a larger soundstage than R5?
I'm currently using the M3X as my primary DAP with the R5 put away for now (in reserve
Well my M11 Pro (SS version) is the largest DAP I own, especially when you consider thickness. Perhaps the picture is a bit misleading. The SS version weighs twice as much as the M3X as well. I can't comfortably carry it in my shirt pocket, which is my preferred spot, both due to size and weight. I believe most would consider the 4497 DAC to be superior to the Sabre DAC in the M3X but you do pay the price in battery life and excess heat (and purchase $$$). I'm not the guy who can tell much of a difference between quality DACs so I'm not going to tell you that one sounds better than the other, I honestly don't know. To me, they both sound great. I do like that the M11 Pro has both 2.5 and 4.4 mm balanced jacks, however. The M3X easily has twice the battery life and doesn't heat up when playing which matters to me. I already own both, so I don't have to choose... I actually think they complement each other well if you have room for two DAPs...![]()
Thanks. I already have a m11 (non pro). But it’s large and heavy. I’m thinking to get something smaller with a good balanced output. The M3x checks the boxes.
Well, if you want small, full Android and balanced output, the R5 and M3X are really the only choices in this price range. Here are some comparison charts of current DAPs that I find useful:
http://bit.ly/DAP2021Q2
wow, who made that graphic? it's up-to-date and pretty impressive-looking.Well, if you want small, full Android and balanced output, the R5 and M3X are really the only choices in this price range. Here are some comparison charts of current DAPs that I find useful:
thanks. That doesn’t make it easier. I was already eye balling the r5 also. But have to read a lot more about it. Is see there are 2 versions r5 and r5 saber.
I am getting the sense that the R5 and the M3X are "cut from the same cloth". I almost wonder if HiBy helped Shanling with the design. That used to be HiBy's business model.
Thanks for this, really useful compilationWell, if you want small, full Android and balanced output, the R5 and M3X are really the only choices in this price range. Here are some comparison charts of current DAPs that I find useful:
Thanks all for the information on the M3X. Based a lot on the perspectives here, I bought and am very happy. I had frankly been a bit skeptical about how much improvement I'd get given my CIEMs are all quite efficient, and I was already using a DAC dongle with my iPhone. But it was the need for more storage for my music, as well as desire for AptX BT, that I finally decided to get a DAP. And yes an improvement over the DAC dongle in SE mode, though I wouldn't say huge.
Having balanced though allowed me to use my Dan Clark Aeons with them, which I do when I want more soundstage, or right after a shower, while still wanting some sound isolation. Does a fine job driving the Aeons. However, it's quite noticeable that with sharp quick bass, it doesn't come close to my home DAC/Amp (Topping DX7 Pro). Very noticeable on Tool's Fear Inoculum, even though on low gain I'm listening around 60, so not very loud. That said, for me a small disadvantage as I mostly use the M3X with CIEMs. And when I do use it with the Aeons, I'm satisfied. I didn't expect it to perform as well as a desktop DAC.
Hiby was always about the software for DAPs before they started to make DAPs on their own. As far as i know when Hiby started to get into the DAP hardware business the other brands started to develop and use their own (Android based) software.I know that Hiby had partnerships with Shanling, Cayin, and FiiO before they (Hiby) got into the DAP business. I suspect that arrangement continues to some degree.
