Does Shanling even obey such EU rules? Anyway, scroll down, read the output specs... scroll down further and see the shop is in New Jersey, USA.https://shop.musicteck.com/products/shanling-m3x-portable-music-player?variant=39692684001342 i heard eu version is volume capped? is this one in link eu or international?
Shanling M3X Portable Player - Our smallest Android Player
exile1973
I've not heard anything about a volume cap, in UK, but even if there is I can't go much above 30 on balanced out into BL03 so plenty headroomDoes Shanling even obey such EU rules? Anyway, scroll down, read the output specs... scroll down further and see the shop is in New Jersey, USA.
leo5111
well i did not know if Shanling Complied with it or not so i asked ...thanks....
Interesting to hear this, I am currently using DX160 as my daily drive but I am not impressed by its battery life, usually I have to charge after 3 usages (each is around 1.5-2 hours).I have an experience with DX160 and M3X. I would say M3X is better with a more neutral sound, better UI, a lot better battery life, and an overall better experience. Things, where the DX160 excels, will only be its 1080p display.
DX160 battery is one of the worst i have experienced to date xD Sorry i don't have any experience with the DX80.
exile1973
I would second this. Have both and the very slight sound gain from the DX is more than offset by the M3X battery life.Interesting to hear this, I am currently using DX160 as my daily drive but I am not impressed by its battery life, usually I have to charge after 3 usages (each is around 1.5-2 hours).
leo5111
anyone who can compare Shanling M3X to ibasso DX150 with AMP 6/8? If not my m3x should be here friday
leo5111
output is 10 ohms? do i need a IFI match ? i have audiosense t800
jaggythistle
I’ve been having a problem for awhile which I have mentioned before. Any sd card that I insert doesn’t index right. The cards work fine in any other Dap. I’m scanning in the shanling app, the Hiby app, and Uapp. It scans and picks up maybe 3-5 new albums but the last 40 still remain not in the app. I’ve tried it with another card and nothing seems to work. I’ve even reset the player and it still does the same thing. Any suggestions?
I had a similar problem, and traced it to an issue with Android Media Storage not able to complete a full scan. I ended up installing the Media Re.Scan app (free app and there are other apps available, this one worked for me hence why I mention it) and running a scan it also got stuck, but I could see which album was tripping up the media scans. Deleted the offending album folder, re-ran Media Re.Scan which completed successfully, although takes a while. Doing this should update the Android Media Storage database so it's complete - I checked the size of this before and after (went from around 10MB to 21MB) - so knew it had updated. Plugged back in to laptop to check all albums were showing on the sd card, and then updated the library scans in UAPP and Shanling apps. All good.
Nothing obvious as to why that particular album tripped up the media scans - although I suspect it's something related to ripping errors for three tracks reported by dbPoweramp being enough to throw it off.
Silverlinings
Thanks, I'll give it a try.
Silverlinings
Well I tried it. It picked up some new albums but still doesn’t work right. Oh wellI had a similar problem, and traced it to an issue with Android Media Storage not able to complete a full scan. I ended up installing the Media Re.Scan app (free app and there are other apps available, this one worked for me hence why I mention it) and running a scan it also got stuck, but I could see which album was tripping up the media scans. Deleted the offending album folder, re-ran Media Re.Scan which completed successfully, although takes a while. Doing this should update the Android Media Storage database so it's complete - I checked the size of this before and after (went from around 10MB to 21MB) - so knew it had updated. Plugged back in to laptop to check all albums were showing on the sd card, and then updated the library scans in UAPP and Shanling apps. All good.
leo5111
does this have a thin plastic screen protector? i look in corners i can see it, but is it removable or is it on for good?
TomKoho
Yes, it has a protective film attacheddoes this have a thin plastic screen protector? i look in corners i can see it, but is it removable or is it on for good?
leo5111
is it removable? reason i ask is i have seen a few cellphones that had one on it, but whatever they used sucker was on there for good
TomKoho
I didn't removable test. But it looks just like the spare in the boxis it removable? reason i ask is i have seen a few cellphones that had one on it, but whatever they used sucker was on there for good
leo5111
ok on my fiio the balanced out says balanced, but this one does not is the 4.4 the balanced one? also does anyone know where to get a google play apk that works?
