ayres
- Oct 28, 2009
Hi all, just wondering if there are any cases available for the m2x other than the leather case that shanling sells. i don't do leather.
I received mine M2x on Tuesday. Very nice player. Its not just a replacement upgrade from my M0 that I was expecting as I feel I got a lot more for that extra $100.
Build quality is nice with solid buttons and the fit of the screen and overall presentation is remarkable. Good job Shanling.
The file drop feature over wifi is a nice convent touch and the sound quality is certainly meatier than the M0.
I have only one problem with it.
When using LDAC HQ to the ES100 It gets garbled especially if I touch the player. If I leave it alone its fine for a time but then it has moments of cutting in and out. On LDAC auto its a much better connection, not perfect but mostly stable as long as I don't move the player that much. The distance doesn't really matter.
I ruled out the ES100 and purchased the UP2 and its even worse with the UP2.
Is this just the nature of LDAC HQ or something firmware can solved. With the M0 I never had a drop out on LDAC.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
LDAC HQ, alongside LHDC, are the codecs most sensitive to quality of connection.
But from your message, do I understand it right that when you used M0 as source for ES100, LDAC HQ was fine, but now M2X is showing worse performance? Since they have same Bluetooth implementation, M2X should be same.
Unfortunately it isn’t and much worse. Could this be a problem with my unit? Do you suggest I should exchange it.
Thanks
Dev
I would advice to try it with aptX/AAC. If the problems will continue, it might be some problem with antenna on your unit. If it will be alright, might be some software problem.
Surprisingly no one asked this in this whole 25-pages thread - does it support replaygain? Comparing the price to Hidizs AP80 (which does) I assume it does as well, but want to make sure.
I have another update for future reference. My M2x issues with bluetooth on HQ LDAC was due to what I assume to be a failing Netgear router or possibly a bad channel.
I had to replace my router because it would keep kicking me off over the last few days. I replaced the router with a new Netgear that can switch channels for the best reception if there is interference. I wasn't expecting anything to change with M5s which also has the same issue in HQ LDAC but to my surprise its completely fixed and stable.
I want to thank Shanling and Musictech for great customer service to insure my satisfaction as there was nothing wrong with my M2x. LDAC HQ is still a little sensitive to range and movements because its demanding for the bandwidth. If this happens check your wifi router for interference by changing the channel. Im very pleased right now.
How high is this feature on your to-do list, if I may ask?Unfortunately no replygain in MTouch system for now
