5. Unfortunate limitation of current system setting.Okay so I bought M2X (I also own M0 but it's a bit too small and freezes from time to time). I won't talk about the sound because my ears can hardly hear a difference between this and my phone, I'll focus entirely on the software and build quality.
1. USB DAC is great. In M0 there was a small delay but there is zero delay with M2X.
2. I love the glassy back. It gives it that premium look
3. I don't really like the volume knob compared to M0. It's way too sensitive and a bit too easy to press. In M0 it's impossible to change the volume by slightly touching the knob but it's easy to do so in M2X. Because of this I often find myself changing the volume by 1 or 2 when waking the device. When you rotate the knob in M0, every next volume level is very apparent. In M2X it's more constant, smooth move.
4. Next track/previous track are harder to press than the pause/play button and they make that satisfying "click" sound while the middle button doesn't. I don't like this inconsistency. The middle button is a bit wider than the next/previous buttons but the difference is not big enough to feel it under your finger. The buttons could be a little more protruding but that's personal preference I guess.
5. Rewinding/fast-forwarding with the physical buttons is kinda weird. Firstly, you don't hear the music when doing it, so you don't know when to stop rewinding. I guess that's the only way the processor is able to handle it. Secondly, it works only if you're in the "now playing" screen.
6. This "Wi-Fi file transfer" :8888 website is in Chinese (which is weird because I use English in the player).
7. It's great we can name our playlists unlike in the M0, but why we cannot rename them after they are created?
8. I said it in the M0 thread and I'll say it again. It would be great if you gave us an option to turn off icons in the song lists so we can see more characters. This horizontal name scrolling it hard to pull off, I usually end up scrolling the list vertically.
9. It adds a weird space before "【" even tho there is no space in the file name. https://i.imgur.com/749HJNf.jpg
10. There are some characters it doesn't read (although they are quite uncommon so I don't blame them). For example "[Promare OST] Λsʜᴇs" looks like this - https://i.imgur.com/fbyxKVp.jpg
11. Didn't measure it with a stopwatch in my hand but feels like it scans files a bit slower than the M0? Kinda weird but not a bit deal.
12. It also applies to the M0 but I wish there was an option to turn off displaying album covers. I feel like it would speed up things a little.
13. I'm sad there is no Replay Gain. Come on, Shanling. It's 2019. Cheaper DAPs have it.
14. Update via wifi doesn't work. Or maybe it works but there is no progress bar so no way to tell if the device is downloading the update or not.
15. Songs sent through wifi transfer don't show up in the "Recently Added".
Overall score: 7/10.
6. I urged software team few times to make it bilingual.
7. Overall customization of playlists inside player is limited.
8. Not likely to have one switch that would be doing such a big change to structure of UI.
9/10. Software team is aware of problems with some special letters from different languages.
12. If you think loading album covers is slowing down player, you can change the playback interface to spectrum analyzer or analog decibelmeter to see, if there is any difference.
13. No update on that.
14. What exactly you mean by "doesn't work"? It should either give you message it's already on latest update or start downloading, when it shows progress of download.
15. Noted.
I've got a question for @Shanling or anyone who can answer. With these BLON 03 earphones,
https://www.amazon.com/HiFiHear-Earphone-Diaphragm-Headphone-Detachable/dp/B07TZ2NQCF
and the Shanling M2X
and this cable (or similar)...
https://www.linsoul.com/products/linsoul-hc-08
Would it be better to get the cord fitting the 2.5mm audio jack, or the 3.5mm audio jack? I believe that the 2.5 would would be "balanced", but to be honest I have never used a balanced cord before, and I don't know if it would be appropriate for the BLON and that cord or if it is even better. (I won't be using an amp, just the Shanling M2X).
Thank you to anyone who can help, and sorry for the newbie question.
There should be no problem using these IEMs with balanced 2.5mm cable (I personally always recommend to check if it's connected correctly with multimetr).
Overall people prefer sound out of balanced output on our players, in theory it's the maximum you can get out of the player. It can be downgrade only if the higher output impedance would bring any issue with connected IEMs (think sound changing in CA Andromeda).
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
