It will be a big shame if there is no fix for this or i wont be able to purchase one and have to keep looking, m2s otherwise is a perfect pair for mojo and sounds really nice on its own too as a back up.
Shanling M2s Hi-Res DAP with AK4490 + MUSE8920, Bluetooth, & USB Out
- Thread starter nmatheis
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
All the time mate but because of the big loss in clarity we both hear using the eq i leave it set to off. The bump is in the sub bass thats for sure. It reminds me of when you use eq and you push a bass slider up way too high and it clips and distorts, sounds muddy and horrible. We have all heard this when we have been messing with eq. But i have never heard of a digital signal passing through to a dac having this kind of effect on sound.
From what I understand the M2s supposed to be bit perfect, and I haven't heard anyone else complain about the M2s plus mojo. Maybe you should try to update the firmware, IDK mate but Shanling should chime in about this- it can't be normal. And yes the eq sucks as it it, but luckily m2s sounds pretty good without it. I remember people having problems with the N3 coaxial out.
Who knows hopefully it gets sorted.
The DSD files may be require a higher bandwidth than the Bluetooth subsystem supports.
@Shanling - Are there limitations to what file types can be streamed over the M2s Bluetooth?
Thanks mate for your reply.
I dont think so that bluetooth cannot support due to bandwidth issue.
I have turn on aptx and it shows A on the top of the screen which means aptx is enabled.
@Shanling
Any advise on this?
Olldman
- Apr 27, 2017
I also ran into this problem. I also found strange limitations on bandwidth, flac 192/24 plays perfectly through BT with apt-x, DSD 64 has a bitrate lower, strange.
At least i know i am not alone and my set isnt faulty.
I am still waiting for @Shanling to reply on this issue.
Hopefully its a setup thing and not because2s does not support dsd over bluetooth which will be a big minus point for this dap.
velasfloyd
- Apr 13, 2017
I think Shanling already answered this in the previous page
DSD is not supposed via Bluetooth because of unstable.
Only DSD is limited to play via Bluetooth.
minop
- May 15, 2017
If we consider the Cayin N3 that has (almost) the same hardware, does it have the same issue with Bluetooth-DSD ?
Thats bad
Joseph Lin
- Nov 8, 2016
Did you make this or where did you order it from?my interconnect is ready....but my M2s hasn't shipped yet!
I could have made one but it's a challenge to get the right USB C part...i ordered it from a local DIYer. still having this one exchanged as the mini USB connector wires are "exiting" the wrong direction.
abitdeef
- Oct 30, 2003
Don't sweat it dude, mine was showing it was still in China and it came a day later. The DHL tracking was way behind, assuming they sent it DHL express
oh i hope you're a bearer of good news! really looking forward to receiving them!
abitdeef
- Oct 30, 2003
I must be having an acid flashback, because the smilies/frowns look enormous! :0
abitdeef
- Oct 30, 2003
listening to all the world's a stage- Bytor and the Snowdog on M2s and it sounds awesome. I forget how damn good Rush was before they went synth which I still like, just 'old' Rush showed just how 3 guys can jell. Plus well Geddy and Neil get more props but damn Alex!
Oh dear lord I meant to edit my post not quote it
Total: 9 (members: 0, guests: 9)
