@marflao That is an excellent Noob question.
Here is my experience thus far:
I have the Cayin N3 AND the Shanling M2s. Both have USB-C USB Audio Out.
I can use the USB-C USB Audio Out on the following devices:
Ray Samuels Intruder - DAC/AMP - requires USBC to USB-mini OTG cable. Works perfect every time (Except RSA Intruder DAC is limited to 16/44)
Ray Samuels Predator - DAC/AMP - same as above.
Peachtree Audio Decco-65 - Uses the USBC to USBB cable you pictured above. It is not 100%. Sometimes, I will hit play and nothing happens. Then unplug it and plug it back in and it works.
Unison Research SH DAC/AMP - DOES NOT WORK with Cayin N3 and Shanling M2s
So my answer to you is... You will have to try it. Or find someone who has a Shanling unit (M1, M2s, M3s) AND one of the DACs you have listed above and have them test it.
Here are some links to cables I have used.
https://www.head-fi.org/threads/cay...oax-out-for-150.833932/page-257#post-13686466
https://www.head-fi.org/threads/cay...coax-out-for-150.833932/page-39#post-13377434
I have used the Monoprice cables AND the Belkin cable. I bought 3 Monoprice for $0.72 ea and 1 belkin for $19.99. All 4 acted the same way on the Peachtree and the Unison Research.
Here is an ebay link to some OTG USBC to Micro/Mini ect.
https://www.ebay.com/sch/sis.html?_nkw=4"+Left+Angle+Mini+USB+to+Type+C+OTG+Cable+for+Portable+Digital+Audio+Amplifier&_id=301996140546&&_trksid=p2057872.m2749.l2658
I am thinking about buying an iFi Nano iOne DAC to use with my Shanling M2s into the Unison Research SH amp. I'm hoping that the iFi One works with the Shanling DAPs.
Has anyone successfully used this setup? M2s > iFi Nano iOne DAC > any amp?
