MONVMENTVM
- Jan 14, 2007
Yeah I think you're right. It seems that the actual mount inside is entirely loose, so even though the wheel seems to rotate precisely, it isn't getting registered properly within. It was either glued to the case or soldered to the PCB and came undone or it was mounted to the case and it somehow broke off during assembly.
I honestly hope it broke during assembly and is not glued to the case or soldered to the PCB as this will get loose sooner or later on every device (be it half a year or a couple of years). I should get it replaced though, already talked to Amazon.
