Hi shanling! Is there any plans for podcast and audiobook support like bookmarks. It's super important for lot of us audiobook and podcast lovers.
Thanks
Thanks
Thanks
Thanks
Thanks
Thank you.Clip case now on AliExpress:
https://www.aliexpress.com/item/-/32890279601.html?spm=a2g0s.13010208.99999999.264.98b03c005OANE2
Thank you.
Also now on Amazon:
$6.99
https://www.amazon.com/dp/B07DWVBY5...s=Shanling+Original+M0+Clip+Case+for+Shanling
@Shanling said in next firmware as far as playlistReally like the size and sound of the M0.
Have listened with a couple of my earphones (HLSX Magaosi MGS-BK50, Remax RM-600M), and some earbuds I assembled from parts ordered on AliExpress (using this driver - https://www.aliexpress.com/item/15-...band-equalization-1pair-2pcs/32800609693.html).
One thing I'm missing, that my other DAPs (Shanling M1, M2s, M3s; Cayin N3; Onkyo DP-X1B) can do - is read an .m3u Playlist file, and then play the music tracks.
When I browse to the Playlists folder (where there are 20 .m3u Playlist files), a message pops up, saying "No File Found".
Me too it's a mustAhh, good to know Shanling is addressing the playlists issue, definitely something I need to have.
Is it that it can't read the playlist files or could it be it doesn't like the path where the playlists are stored?
