So I tried it with my phone which use AAC, same problems, heavy static and cut off every 5 min.
However, I tried resetting to factory setting and the problem seems to subdue.
SBC stills have that statics and sometimes, and complete silence for a good 30 sec every now and then but at much more acceptable rate now (I'd say every 1-2 hours). So I guess that's normal for Bluetooth connection? But the effective range is very short, I have to sit within 5 feet from my sources, otherwise the static will come in and cut out happens constantly, which won't go away until I restart the Bluetooth (turn off and on) on M0.
AAC on the other hand seems to work fine even at long range.
One last thing, is shutting itself down when it's fully charged normal behavior for the M0?
In my experience, AAC is always codec with best connection. For that reason you see so many truly wireless IEMs using AAC.
Can you tell me what source/phone are you using when facing these problems with SBC?
Shutting down on fully charge is change software team made to both M0 and M5s. They didn't really looked into all user scenarios, so we will need to adjust it a little bit to be more practical.
Hi all,
Just bought an M0 (coming from a previous M1). Love the thing. Seems there's still some issues with the m3u playlists when the song has special characters in the metadata.Saw previous comments that you're still working on both things so I don't care much.
Example: In the below file the M0 only shows until song 3 (releaser). As if the playlist only included those 3 songs. FW: 2.3 so it's on the latest update.
M1 can handle it okay (no problems whatsoever with this same playlist), and even when it can't handle it, shows as a file that can't play or some errors in the name and skips it.
Also, felt that the leather case would benefit from a lanyard attachment so I modded mine. Even made me a leather Shanling lanyard from an old elastic lanyard I had around. Ended up all super solid and secure (Don't wan't to drop this little guy).
Pictures below.
Will see if I can make some playlist with similar thing to test it out.
Shanling , could you please write a script so that when playing the MO in the car the artist and track information come up with
a Bluetooth connection ?
Thanks .
Unfortunately this is not about script, but about using different BT profile. No plans to add it now, since it could be causing some other problems.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
