fish1050
It works without problems with latest iPhones using AAC codec.
Thanks, will see if we can replicate this problem with any of our BT headphones.
1. We are discussing some changes to UI.
2. Not planning to adding such function of wheel turns changing tracks.
3. Will see if I can talk with them about adding some other time settings.
4. Currently there is no way how to rename playlists.
5. This seems like something that would take significant work, yet would be used by very limited amount of users. So unfortunately no.
ES9218P is combined SoC, signal always goes through its amplifier stage.
Of course you can use it with external amplifier, without any problems.
So the UI changes being discussed, are they changes to the existing UI or will it involve porting MTouch 2.0 elements into the M0 as you mentioned several months ago?
