Gotta be a lil more patient folks . Int’l release end of May
Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
- Thread starter Shanling
- Tags
- dap ldac shanling shanling m0
I'm also curious about this. Since they mention it will output 2vrms.Considering the M0 has a newer gen DAC chip inside, I want to try it out with some of my desktop amps.
I usually use the line-out on my current DAP, but for the M0 should I just use it on max volume output?
HiFlight
Should work just fine as line-out at 100%.Considering the M0 has a newer gen DAC chip inside, I want to try it out with some of my desktop amps.
Yes, put it on 100% and you will get cleanest 2V signal.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Question for Shanling:
What file systems will be supported on the microSD / TF card?
Akulagr
Any resellers in Europe stocking the M0 for pre-orders?
Headphoniaks.com already has the preorder page, gettin mine from there.Any resellers in Europe stocking the M0 for pre-orders?
But you can also wait for advancedmp3players.co.uk
Akulagr
Awesome! Thanks for the info.Headphoniaks.com already has the preorder page, gettin mine from there.
I think I'm going to go ahead and pre-order from headphoniaks.
gregb
- Jun 21, 2015
I have pre-ordered it on audiophonics.fr for 119€
It says "05/05/2018", we will see...
It's probably very expensive but I buy on this website since a long time.
I'm quite sure they will be the first to deliver in France.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
If you can wait for amp 3 you will get another 10 percent off, plus with may around the corner there could be other offers on as well. Up to you.Awesome! Thanks for the info.
Amp 3? What is that?If you can wait for amp 3 you will get another 10 percent off, plus with may around the corner there could be other offers on as well. Up to you.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Shorthand for advancedmp3players in the uk.
Akulagr
Do you happen to know when will they release it or have it up for pre-order?If you can wait for amp 3 you will get another 10 percent off, plus with may around the corner there could be other offers on as well. Up to you.
eaglesgift
It says available end of April/early May on the first page?Gotta be a lil more patient folks . Int’l release end of May
a question: in addition to the case, do you also think about a protective film for the screen?
Total: 13 (members: 0, guests: 13)
