It only shows on files with too long name, it's part of the "blurring". Will ask if it can be improved.
OK thanks!
it's not a real problem, most of the time the display is off and I do not notice it
also i want to ask, is shanling m0 can downgrade the fw?
want to try the custom fw 2.2, but if i encounter a problem, i can go back to 2.2... or even 2.1
I was uploading firmware quickly on Monday in last 5 minutes before my work ended. Next day direct link to update file was posted and you can find it on first page since then.
Oh, tested it now, I see it only affects sorting in My Music, while it works just fine in folder view, correct?
I will report it and have it hopefully fixed in next firmware.
Thank you, will report to engineers for some explanation
This is an RTFM problem.
What does your charger do when the user plugs in a non-Quick Charge compliant device?
As you haven't told us what the make and model of charger is, we cannot answer this question for you.
I don't have the manual.
It still charges it.
This is my QC 3.0 wall charger.
It does say on there:
- Safe to use: only adopts premium components and smart circuit protections to keep you and your devices safe anytime
So I assume it's fine, unless someone says otherwise.
Thanks!
Your charger automatically regulates the output voltage and amperage. You won’t get fast charging, but it will be much faster than usb from a pc or lappy. M0 will be fine, it also has a voltage regulator
Ok awesome!! Thank you so very much abitdeef!!!!!!!!!!
Planning on doing the firmware update today and I was just wondering if any of you who have done the update notice any changes in usability?
I am thinking mainly of the accuracy of the scroll wheel and the touchscreen. Kind of hoping @Shanling will provide a list of the minor updates made with this firmware update at some point. I am looking forward to trying external playlists. With my Sony A17 and MediaGo software external playlists were a breeze to import. I started using Media Monkey but I have noticed there is no option for choosing absolute or virtual paths for exporting playlists.
Can you guys recommend a good program for handling external playlists for Windows?
I've long been a fan of MediaMonkey to manage my library and create/sync playlists. MusicBee is also quite good.
