piratenpanda
I'd also love to see some lock functionality. Like when enabled you need to press the wheel for 5s or something like that to unlock.
As i said the problem exist on all files like this (1 flac file 1 cue sheet)Can you please send me your file showing this problem?
Fix in this firmware was mainly for the albums where songs 2/3.4/5.6/7, etc were switched.
Great work buddy! You should sell theseI have found a problem that the plastic case does not solve: the side button being pressed or moved by my clothes in the pockets of trousers or coats. This switches the M0 on (or off as the case may be) and it is a nuisance.
I have created a 3D printed box that can be used as a clip, but also as a protection to the M0: it covers most of the wheel, while allowing to use it; it also covers the screen borders - I have many a broken phone due to falling on the floor with the wrong angle.
Sure, You're welcome to help me to fix the languages!Also where can I provide translation fixes? Some things are really funny but should still be fixed
In reality, it is only thick in the knob area - the other side looks thick but in reality it is a bezel to protect the screen border:Very cool looking, Iooks sturdy- unlike the flimsy oem case. I would buy one Question, could you make the sides a bit thinner? NM, duh you did that intentionally to prevent the knob being accidental pressed.
I presume you're looking for beta testers to ship free demo units to before you go into mass production?...In reality, it is only thick in the knob area - the other side looks thick but in reality it is a bezel to protect the screen border:
I informed you about this issue on July via p.m . if you look your pm you will find also the files you need
I want to know if this issue will be solved in future update or this is not your priority (as your priority is to release M5s and some IEMS)
This is not the issue i am talking aboutalbums where songs 2/3.4/5.6/7, etc were switched has certainly been solved
Are you gonna sell the 3d file or cases? It looks fantastic.In reality, it is only thick in the knob area - the other side looks thick but in reality it is a bezel to protect the screen border:
LOL
so much waiting and the problem 5 is not solved
The problem exist not on all albums but only on the one that are in one file and a cue sheet (the id tags are correct)
the songs listed in alphabetical order and not by their track number
If i browse via "Folders" there is no problem
For me it is big problem as i am album listener
You will do something about that or no?
Ok it's a cue sheet issue? does it not use M3u?
