I'm busy with work and life most times but here are a few more photos for now in case I don't get a chance to go through all of the rest and upload them.
I think even just these few photos will help those who are interested, not just for the volume wheel issue but for other things too.
Maybe someday I'll also remove the PCB and post more photos including the battery or someone else will do so before then.
Thanks FranticPhil for the compliment. Appreciated. It's nice to help if possible.
This is a quality 30mm suction cup from a hardware store used for glass and mirrors.
Those 2 ESS chips are the same.
Here's a good revealing shot. PCB is attached with standard phillips screws. Battery connector at the bottom left (connector lifts up).
The infamous volume wheel potentiometer & power button is contained in the small aluminum box and attached to the PCB with a snap connector.
A tip when working on the player and not wanting to disconnect the display connector is to hold it up and back with a piece of tape attached to the body.
GigaDevice and Realtek chips. Bluetooth antenna gold connector partially seen to the right.
Here'a a closeup of the power button and volume potentiometer assembly during the 1st opening. You can clearly see in my player how the pot was not mounted flush to the board and as stated before, not enough solder on the pins resulting in the random volume response and eventually no response whatsoever. Normal movement of the wheel and button press resulted in the unsubstantial amount of solder on the pin(s) to become fully disconnected.
For people who perform a swap repair with a new assembly, it can help to reference this photo for reassembly because the power button sits slightly high and not exactly centered in the box, nor does it recess further into the pot.
Ok. The blackened aluminum wheel is designed to be pulled out with some decent but not excessive force. Then the brass collar nut can be unscrewed with a small pair of pliars. Finally, it is required to use pointed tweezers to pull out the small plastic shaft pin (see the next photo after this one).
Use a pair of pointed tweezers to pull out the plastic shaft pin that is held in place by the brass collar nut and keeps the power button/volume potentiometer assembly from being lifted out. With the pin removed, the assembly is then easily lifted out with a toothpick, etc. (see the next photo after this one). It is most certainly not required to perform any further disassembly of the player. The board can remain in place for example.
Here the power button/volume potentiometer assembly is freshly lifted out of its housing by placing a toothpick under the ribbon cable and leveraging it upward. Be careful as the cable is fragile and do not perform this action too many times. I learned the hard way and eventually broken the cable fully in half from too much diagonstic work!
This final photo for now is just a shot of that mysterious push button switch. Like I said, maybe it's for diagnosing purposes and those 4 pads might be for jtag. I hastily pressed it out of curiosity and thankfully it did not reset the player. Shanling representative, do you know what this is for?
That's all for now. I just wanted to at least get these up here in case I never get around to processing more photos. I really believe these will be quite helpful though.
Let's get more M0 buyers and fans on board.
And no I am absolutely not paid by Shanling. Just passionate. I've said so many times that I think this is a great player and quite future-proof. And one to hold the reign in this niche genre class for quite a while. Let's keep it popular and in production and maybe Shanling or a passionate 3rd party working with Shanling will even setup a proper storefront for easily ordered and affordable spare parts.
The most mechanical item and most prone to failure is of course this volume wheel assembly. I'm trying to help show and simplify the repair process. We just need the support on the other end for the ease and affordability of ordering replacements. Many people can certainly perform this repair on their own.
Oh, and someone to hopefully port Rockbox OS/firmware to this player some day in the future! To inlcude of course recognizing the .m4b extenion if Shanling never gets around to making the super simple and easy adjustment for that in the firmware.
Thanks again Shanling for this great device!
