Shanling ET3 - Dedicated Digital CD Transport, With USB Drive and Wi-Fi Support
Feb 1, 2024 at 2:05 PM Post #586 of 1,495
I tested this Brian Eno disc on my old player and on my PS3 and both were able to play it without any problems.
Still could be the disc.
I ran into a similar situation ripping movies. The Bluray would play fine, but I couldn't rip it. Then I did some investigating and discovered what I mentioned before.
IIRC the CDT in the ET3 is not an CD audio only transport.
Feb 1, 2024 at 2:07 PM Post #587 of 1,495
I believe I have two copies of this, an early 90's version and one of the early 2000's remasters. I will check. From the label, I don't believe I have the exact release unfortunately.
Feb 1, 2024 at 8:37 PM Post #588 of 1,495
Unfortunately, my view on Shanling ET3 is not so optimistic. In addition to the SRC problem, I encountered several other serious flaws.
1. The ET 3 has problems playing some CDs in my collection. These CDs are in perfect condition and play without problems on my old player.
2. Bluetooth always in pairing mode even if it is already paired with my device and bluetooth input is not active. I find it unacceptable that a device connected to my private wifi network is also freely available to all my neighbors.
3) Apparently there is a wrong way to close the lid that is visually indistinguishable from the correct way. When this happens, the ET3 makes terrible noises when playing discs. I manage to close the lid incorrectly 1 time out of 10.
So I exchanged the ET3 for another transport. It's very sad because I really liked the sound, design and feel of the ET3.
1. I will report the CDs you posted to our engineers for check, bot this is something we see only very rarely.
2. You can turn off Bluetooth or Wi-Fi if you are worried about privacy.
3. Did you keep any picture or video showing how you put the lid on? The puck snaps into the correct position by magnets, the lid just fits flush with the outer opening. If you managed to put it on only 1 out o 10 times, there might have been something wrong with your unit or lid.
@Shanling Sure the BT can possibly have an on/off switch? Other solution?
Have not had any sort of trouble with the lid, no terrible noise.
Also @Shanling is consistently engaging with and providing insightful comments on the majority of posts in this forum, that deserves commendation. We appreciate the effort and hope that these issues can be resolved.
There is Bluetooth On/Off switch right in the menu.
Feb 2, 2024 at 4:17 AM Post #590 of 1,495
2) This is a rather inconvenient solution. It would be better if pairing mode was only active when bluetooth input is selected and under one of the following conditions:
1. There are no paired devices
2. Could not connect to any of the paired devices
3) I didn’t take a photo because when I was encountering noise, the position of the lid was indistinguishable from normal. I assumed the problem was with the lid because removing it and putting it back was fixing the noise.
Since I am the only one who encountered this problem, then most likely it is a defective unit.
Feb 2, 2024 at 12:17 PM Post #591 of 1,495
For example Brian Eno - Ambient 1: Music for Airports. ET3 especialy strugling with this one. When I press play for the first time, ET3 freezes at 00.00 for a while and stops. If I press play a second time it starts playing but stops every 3-5 seconds. As you can see disk in perfect condition.
ET3 already have bt on\off switch. It should have pairing switch.
Aye, actually I do have the same CD, that’s the early 2000s I mentioned.
No problems spinning it. In and out multiple times, and played
thru twice last night no skips or errors.
You probably have a defective unit, with all the problems you encountered.
Feb 5, 2024 at 1:59 PM Post #592 of 1,495
@Shanling May be a new bug when playing MQA CD ?
My set up: ET3 CTD to R2R Gustard R26 DAC via AES connection. When playing a MQA CD, in SRC bypass mode, noise coming out the speaker constantly while the DAC displays bits rate blinks as well by second. Switch to SRC PCM 192kHZ, both noise and blinking display on the DCA are gone, and the sound quality is great.
Feb 5, 2024 at 9:05 PM Post #593 of 1,495
What's your MQA setting on ET3? Does your DAC support MQA?
Feb 6, 2024 at 1:02 AM Post #595 of 1,495
I just got the ET3 a few days ago. I manage to connect the WiFi using Synclink but I cannot make the Bluetooth working. It is pair with my android phone, Samsung, but cannot connect it. How should I connect the Bluetooth?
Feb 7, 2024 at 9:34 AM Post #596 of 1,495
Today, I have tried using ipad to play Spotify through ET3 and I am able to play it and sounds good. I have not compare it to my Lumin U1 mini streamer but I can imagine I will not miss my Lumin U1 mini. I an using i2s connection. However I still cannot connect my Bluetooth using android phone.
Feb 7, 2024 at 1:01 PM Post #597 of 1,495
Just gotta spill the beans on this ET3 thing. To anyone possibly reading this post, and thinking about purchasing the ET3.
If you're into a CD experience that's more chill, organic, and kinda warm, this thing's the real deal.
Not gonna gush like a love-struck teenager, but seriously, ET3 has some cool vibes. It's like my tunes got an upgrade – smoother, warmer, you name it. If you're on the lookout for a new audio sidekick, this one's worth checking out. This is without SRC.
I just bought the ET3 and this is pretty much all I want to see :-) Real deal and cool vibes...
Feb 7, 2024 at 7:16 PM Post #598 of 1,495
Does ET3 when sett to Bluetooth mode show it's connected and what codec is used?
You said it works fine with iPad. Do you have any other Android device to test?
What Samsung phone are you using?
Feb 7, 2024 at 8:33 PM Post #600 of 1,495
Trying to set up sync link on android causes my ET3 to freeze. I have to use iOS. I’m using a galaxy zflip5.
