I too bought the new Momentum and I agree with the comfort issue, clamp force is simply a little too high. Currently I'm trying to tone down the clamp force by bending the metal over night.
Sound wise, I managed to tone down the bass and up the highs with the included EQ app so now they sound similar to my DT990 Edition but with slightly more bass and without the beyerdynamic peak highs. I have the QC35 for comparison and sound quality is definately better on the Momentum but the QC35 still wins comfort wise of course - and the noice cancellation is better on the QC35, but I do like that the Momentums do not generate as much of a pressure sensation with high ANC setting, so the Momentum's ANC is alright and well balanced. I really like the transparent hearing function, my impression is that it works better than on other ANC headphones.
I mainly bought them because of aptx low latency because I want to use them for gaming and videos as well. It's a shame Bose/Sony do not update their headphones with aptx low latency support...
Do not care about aptx HD cause I'm not an audiophile person enough for that to hear a difference
One issue I have with the Momentums is that there is audible wireless communication noise you can hear when the headphone is on maximum volume and nothing is playing - but this is not an issue at ~70% volume so it's still acceptable.
Another issue I have is that when two connections are established, the headphone seems to have problems with aptx low latency and has some interruptions and distortions sometimes. Workaround is simply to only have one connection when using aptx low latency - so also acceptable.
