That’s how it should be lolSo you returned it solely based on comfort?
Would you wear a shoe that’s uncomfortable? I wouldn’t haha
I found the IE900 uncomfortable, with inconsistent sound, inconsistent fit across tips (requires me to re buy tips in either a larger or smaller size due to stock tips not being any good), tips significantly altered sound, need to replace the finicky cable, and since there’s suitable options for less money I don’t see any point using it.
I experimented for two hours. I shouldn’t have to put in this much work for a product to work. I suspect if this was a generic chifi product, there wouldn’t be as many apologists. I will try one more time today (before I ship it off) as I have MEST MKII coming in, I would like to do a sound comparison at very least.
I will say the brief moments I got it to work, I found the bass to be better than the Legend X. No other iem has managed to stand toe to toe, let alone win out compared to Legend X. Very impressive tuning.
Edit: To the PM's coming in, if anyone is looking to replace stock cable,
Edit 2: ie900 seems to use a special implemented mmcx, so not all mmcx cables will work...the plot thickens haha
