Guys, any ear tips suggestion for the IE 900? The stock ear tips doesn’t fit me properly.
Sennheiser IE900 Review, Measurements, & Harman Target Talk
- Thread starter jude
rarewolf
For my IE600 IEMs, I liked the Spinfit CP145 tips the best for isolation, sound quality and comfort. That said, the Sennheiser nozzles allowed them to slip off relatively easy. I’m using the Azla SednaEarfitLights now, they’re not quite as comfy, but the isolation and sound is good.
Thanks rarewolf! Spinfits are usually very comfortable for me. I will try the CP145.For my IE600 IEMs, I liked the Spinfit CP145 tips the best for isolation, sound quality and comfort. That said, the Sennheiser nozzles allowed them to slip off relatively easy. I’m using the Azla SednaEarfitLights now, they’re not quite as comfy, but the isolation and sound is good.
rwelles
I've been happy with the Sennheiser IE Pro tips. Thicker than the stock tips yet very comfortable.Guys, any ear tips suggestion for the IE 900? The stock ear tips doesn’t fit me properly.
I use Sony hybrid tips. I find these stay more securely in the first outer nozzle position.Guys, any ear tips suggestion for the IE 900? The stock ear tips doesn’t fit me properly.
newworld666
I agree.. same here.I've been happy with the Sennheiser IE Pro tips. Thicker than the stock tips yet very comfortable.
With my ears canals those are definitely the best fit with IE900 and IE600..
The IE PRO L tips can stay for hours without any change, even if my head is moving or on the side on a cushion.. So with those, I get the full sound frequency range available for hours.
With the Vision EXT the spinfit CP 155 are more suitable for my hears as the drivers noses are oval... I tried them too (with many others) but the IE PRO L tips for the IE900/600 are which I would recommend to try.
The sony's IER Z1R hybrid tips are perfect with the Z1R in my ears, but less stable in my ear canal when they are used with the IE900.
Be sure to try "stage 1" and "stage 2" positions for the stock eartips, as many have found that adjusting the position on the nozzle can make a world of difference.Guys, any ear tips suggestion for the IE 900? The stock ear tips doesn’t fit me properly.
Stay updated on Sennheiser at their sponsor profile on Head-Fi.
adeeb
- Nov 13, 2016
I’d love to try that but I can never get the stock foam tips to stay in the outer position. Sennheiser should have included rubber spacers.Be sure to try "stage 1" and "stage 2" positions for the stock eartips, as many have found that adjusting the position on the nozzle can make a world of difference.
MarkParity
Perhaps try the next size down or pre squish the tips a bit. If the tips are slipping inwards then obviously the friction between your lug hole and tip is greater than the friction between the tip and the sound tube. I never have this issue but then I use the medium silicone tip and prefer a looser fit.I’d love to try that but I can never get the stock foam tips to stay in the outer position. Sennheiser should have included rubber spacers.
Azla SednaEarfit Light (the regular version, not the short one) for me too.
rwelles
Pop down to your local hardware store and grab a couple of rubber grommets, 4.5 mm ID with a 1.5 mm thickness. Costs about 50¢.I’d love to try that but I can never get the stock foam tips to stay in the outer position. Sennheiser should have included rubber spacers.
I never tried that. Let me try. Thank you!Be sure to try "stage 1" and "stage 2" positions for the stock eartips, as many have found that adjusting the position on the nozzle can make a world of difference.
walkmanforever
- Jan 24, 2011
Hi there. Could you please share the purchase link?I've been happy with the Sennheiser IE Pro tips. Thicker than the stock tips yet very comfortable.
rwelles
https://earphonesplus.com/replacement-ear-tips-for-sennheiser-earbuds-see-list/Hi there. Could you please share the purchase link?
Hey Guys,
I tried different tips, but couldn’t get proper fit. It’s my ears. Only a very few IEMs work well with my ears. I’m thinking about selying IE900. It’s just been a week since I bought. Less than 3 hours of usage. If you are interested please DM me. $1400 (including shipping). Thanks for all the suggestions!
