One question, I would mainly use them with the 2.5 balanced cable, is there a good difference in sound quality with the 3.5 output?
Thank you
Thank you
Depends on the source, my DX300 has enough juice to run the IE900 unbalanced but some weaker sources (e.g. dongles and various bluetooth DACs) might not be able to drive it with their 3.5 output. UP5 is an example of this, 3.5 is okay-ish at best and 4.4 is alright for on the go usage.One question, I would mainly use them with the 2.5 balanced cable, is there a good difference in sound quality with the 3.5 output?
Thank you
It’s not so much the cable or termination themselves that determines sound quality, but rather the source you’re connecting to. Generally speaking, balanced connections (2.5mm & 4.4mm) will sound better, due to having each channel completely separated for a cleaner signal path, reduced crosstalk, and in most cases being able to deliver more power than single-ended (3.5mm).One question, I would mainly use them with the 2.5 balanced cable, is there a good difference in sound quality with the 3.5 output?
Thank you
OK thank you. I am using the btr5, mainly connected by usb, but I was thinking of something more powerful and with a better battery.It’s not so much the cable or termination themselves that determines sound quality, but rather the source you’re connecting to. Generally speaking, balanced connections (2.5mm & 4.4mm) will sound better, due to having each channel completely separated for a cleaner signal path, reduced crosstalk, and in most cases, being able to deliver more power than single-ended (3.5mm).
An exception to this is if you’re using a very sensitive IEM that’s prone to hiss or requires a low impedance. In that case, you’d want to try your 3.5mm connection because it probably has less output power and possibly a lower output impedance than balanced. Luckily, IE900 isn’t overly sensitive, so you shouldn’t have this issue
TLDR - for IE900 I’d say 2.5mm will probably sound better.
I use a Luxury & Precision W2 for my IE900. In high gain using the 4.4mm port, It powers them well and sounds excellent.OK thank you. I am using the btr5, mainly connected by usb, but I was thinking of something more powerful and with a better battery.
how do you see the ie900 for metal music?
I love mine with the W2 too but looking to get a DAP as well. I see you have quite a collection of DAPs. What do you think is the best pairing with regards to the DAPs that you have with the IE900? Mind doing a rank list with your collection? You can leave out DMP thoughI use a Luxury & Precision W2 for my IE900. In high gain using the 4.4mm port, It powers them well and sounds excellent.
I don’t listen to a lot of metal so I’m not really qualified to comment lol, but I assume IE900’s big bass, weighty lower midrange and sparkly treble should work well for metal.
My favourite DAP for IE900 is one I don't even own anymore - Cayin N6ii with the R01 module. Very nice pair up with those two.I love mine with the W2 too but looking to get a DAP as well. I see you have quite a collection of DAPs. What do you think is the best pairing with regards to the DAPs that you have with the IE900? Mind doing a rank list with your collection? You can leave out DMP though
Much thanks! N6ii R01 is on my list as well. But it is Android 8.1. Do you think it’s still worth to get it now? I will stream on Apple Music if I get one.My favourite DAP for IE900 is one I don't even own anymore - Cayin N6ii with the R01 module. Very nice pair up with those two.
Ranking what I own currently:
1. iBasso DX300 Max Ti
2. A&K SP2000
3. FiiO M17
4. Shanling M9
2. A&K SP2000
3. FiiO M17
4. Shanling M9
Very happy IE900 + (N6ii + R01 + A02) + C9 owner here. Absolutely great sound quality and strongly musical (forgive this word) character, great synergy, very coherent and involving, just natural.Much thanks! N6ii R01 is on my list as well. But it is Android 8.1. Do you think it’s still worth to get it now? I will stream on Apple Music if I get one.
waiting for stock and no expected date, bad luck, at least they will give me a 10 percent discount for the inconvenience.Hello, here's another one with the ie900 on the way. I hope they are really worth it, since with the ie300 with the fiio lc-2.5d cable I am very satisfied.
I also sometimes use the fiio fa9 which are very analytical but very boring in comparison.
greetings to all from Spain and congratulations for this great community
I'm pretty happy using the Cayin RU6 with IE900. Good match up when I do not have space for the 3Max.Much thanks! N6ii R01 is on my list as well. But it is Android 8.1. Do you think it’s still worth to get it now? I will stream on Apple Music if I get one.
