what? How did you get all that from what I wrote? I meant a successor in the same vein as the IE80, IE800 is the flagship but not a vis a vis successor or newer model meant to supplant the IE80. Right?
Edit: There is a German audio show going on right? Maybe they are showing off prototypes to select people. Has been known to happen before.
I agree with you here. Sorry, i just fiind ie800 cables to be the turn off point of them, i am afraid that they will harden due to sweat at any moment, so i am a little too afraid to buy ie800, so i thought that you might be in the same situation.
I tested both ie80 and own ie8, i was unable to tell which is which. Adding tape over the vents, but leaving a hole was much more efficient at changing the signature.
I would had loved ie80 to had solved all the problems with ie8, like it had mids a little too recessed, the treble was not loud enough, midbass 100hz was a little too much, clarity could had been better, and separation could had been better. All of these solved with ie800, but it has cable problems, which are known, the cables harden due to sweat, and eventually break. It is great though that they change the broken ones.
In fact, i think that if they were to create ie800 in ie80 enclosure, with detachable cables, but with ie800 tips, it would rule everything.
I still hope for ie800 sound within ie80 enclosure at ie80 price.
