An attempt to remedy the failings of Sennheisers R&D team with a bit of Sellotape.
Sennheiser IE80's Impressions Thread
- Thread starter Craigerz
It's just a small tape covering the bass screw hole in order to tame the bass and give more clarity to the mids, it's just a signature preference change.
You can try it very easy and remove the tape if you dont like the result.
pacman46
- Dec 30, 2012
I haven't listened to my ie80's for a little while. I was listening to some other iems in my collection for a while.but I put them back in a couple weeks ago and yeah..there is the music again..and to make it clear..I am not a bass head but dam I forgot how good these sound.. Ive sold and traded other isms that are BA iems..these sound incredible ..these are one pair that I will probably always keep..they let me just listen to the music..love them ..
burtomr
- Apr 30, 2011
.....I am considering getting one of these decals http://www.decalgirl.com/skins/HTC-One-Skins
To use as a tape mod. The HTC one is made of brushed aluminum so it might work just as well on our IE80s.
Now I'm not too sure if it will stick as well as tape. What is everyone thoughts on this? (Tape mod users).
You would actually buy a whole iphone skin just to cut it up for the little squares needed to cover the back of your 80's? For a second I thought you were serious....
If you were actually serious (I hope not) please just use a piece of good-ole Scotch Tape...it's clear cheap and won't have you slaughtering a poor defenseless iphone cover just for it's skin.
NoctisLE
- Feb 13, 2014
Yea why not? 10 dollars is pretty minuscule compared to the price we all pay for the audio stuff we purchase.
burtomr
- Apr 30, 2011
Murderer!
Be aware that if the skin is removable, it may not seal well to the back of the 80 due to the not so sticky adhesive. If it leaks it won't do the job. You can find stainless steel tape at any good hardware store - used for patching A/C & Heating units which will match the 80's SS back. It has very good adhesive, too. But I think clear tape is the best since you can see right through it....or just cut a round piece with a hole punch and cover only the adjustment screw hole.
"Less is Best"
yehgermeister
- Dec 13, 2009
Is there a US web store or brick and mortar store where I can get a stock replacement cable for my IE80s?
castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
if it has to be in the US you can try moon audio.
burtomr
- Apr 30, 2011
Here's the part numbers: LINK
IE80 Cables:
P/N 545270 (Standard)
P/N 545271 (Short)
Can't find them w/Google in the US but maybe the Sennheiser USA store (below) can get it for you, ditto for Full Compass. Or use the IE8 cable which will work fine, too.
IE8 Cable:
P/N 525719
SennheiserUSA Store: LINK
Full Compass (Official US Dealer): LINK In stock
MRiNiCK
- Dec 13, 2010
IE80, Westone W40, or Heir Audio 4AI? down to 3 IEM to choose from
burtomr
- Apr 30, 2011
What about the Noble 3 or 4?
Noble's designer, Dr. Moulton (aka Wizard), is the original designer of the Heir 4, started his own company.
LINK
john423
- Aug 19, 2013
Should I buy these or the sony xba h3 or the ue 900?
willyvlyminck
- Jul 30, 2012
Nobody can answer this, as we all hear different, from my own experience I would go for the IE80, wich is already a classic and like the big 600-650 will stay with us for a Long time to come,.
Be aware though that the IE80 is a very coloured sound. Well if as reported it is the same as the IE8 that is.
Is there no way you can try before you buy?
Some on line suppliers accept returns. In the UK there are retailers with demo models...
jerrick85
- Nov 12, 2013
Never heard hba h3, but ie80 and ue900 sounds differently. Ue900 has build issues and feels very fragile, that I always take extra care when changing cables. IE80 is very sturdy and never got any issues so far. Build wise I always prefer ie80.
