aras
- Oct 17, 2012
So does it do something or not ? I guess I will have to try it myself.
i want to share my way on how to increase isolation,seal and fit with the ie80.
have an big eartips and small eartips (any big tips(i use JVC) and any small tips can be use here)
put the small tips inside the big tips
put the eartips in the ie80 and you are done
if the small eartips is to tight for the big eartips please cut this part on the small eartips
Hope it works for you guys
hey guys
what is this door in the back of the case for????????????
exactly. desiccants are your headphone's best friend.
I think that little bag dries the air in the box
do i need to change them in a while??????
You are in the long quest for the right tips for your ears, I have spend a lot of time also for the IE-80, you can try the JVC tips, they do wonders for me, I found it on Ebay and they are cheap. You can also do a search in this thread to find some interesting links posted before.
The last solution can be the ACS custom tips, but this is another story : http://www.head-fi.org/t/415905/review-acs-custom-tips-sennheiser-ie8
