Sennheiser IE800 IEM's
post-13348228
Post #6,646 of 7,769
kuebler
  You've dashed my high hopes from Hungaria...
I know what you mean and I'm sorry for that...
I have to say I was surprised from the first minute I unpacked them: they are so stiff, and other than I remember to have read, they don't have any foam characteristic.
Strange, because the guy introducing them here (don't remember who) should have told us. At least somebody made sort of a recommendation, otherwise I wouldn't have bought them.
Originally Posted by les_garten /img/forum/go_quote.gif
You're right, the stock ones can be made to work as long as you don't move a muscle.
I have to say that I wasn't immediately happy with the fit (but also not really unhappy). But after carefully and extensively experimenting (I ended with oval M left and round M right) I did find the fit quite well. To give an impression: left fits the millisecond I plug them in, right needs 5..10 seconds of "optimizing" on the high level achieved with the very first plug.
But then they sit like specially made for me, they isolate quite well (a good measure of the quality of the fit), and they are reasonably insensitive to jaw movements. I tried to imagine whether I could eat with them. Probably even that, if it wouldn't be just a giant sized hamburger... :wink:
The more I think about it, the more I want to highlight the importance of selecting the right ear tips, and I believe, that even very subtle manufacturing tolerances can have an influence. So it might have helped for me, that I tried from a wealth of clone tips and some Sennheiser's. Anecdotal remark: the two tips I use now are both clones. I cannot really argue why, maybe it's my somewhat "Scottish" mentality :wink:
post-13348281
Post #6,647 of 7,769
les_garten
You've given me some motivation to play around with the fit.
I also never thought about fitting them asymmetrically either.  Thanx for that!
I'll add the Hungarians to my collection box...
post-13348509
Post #6,648 of 7,769
mathi8vadhanan
  I had used this adapter, with Noble's bluetooth clip. Though it's TRRS, both channels worked fine.
I recommend this TRS adapter, to be on the safe side.
Sooooo many thanks!
May I ask, what's "TRRS" and "TRS"?
BTW: I also have a Noble BTS, but its battery is extremely weak (max. 1.5-2 hours)
It's the pin configuration. Tip-Ring-Ring-Sleeve (TRRS) vs Tip-Ring-Sleeve (TRS).
When plugging TRRS male in to TRS female:
Based on where the pin contact is available for Sleeve(in the female part), you may/may-not hear one of the channels.
Reactions: kuebler
post-13349171
Post #6,649 of 7,769
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
About the fit: On ie800, the fit is the hardest thing to get right. But when you do, you do get it right
post-13349317
Post #6,650 of 7,769
kuebler
Agreed.
But what else should be hard? Listening?
And it's no magic, it's just work. And not extremely much, but it must be done, and carefully.
Trying to escape into miracle solutions is just, hmmm... "escaping into miracle solutions"...
post-13349477
Post #6,651 of 7,769
Dobrescu George
Bucharest, Romania
Bucharest, Romania
Age
25
Website
Agreed.
Oh, with some headphones, EQ can be hard, with some the noise leakeage can be too much / isolation too little, there can be problems in sound.
With ie800, to get the right can be hard.
post-13349551
Post #6,652 of 7,769
kuebler
Not sure, what you really mean... I'm not talking about headphones...
And with the IE800 finding a good-to-perfect fit is not easy, but it can be done with some consciousness, planning and care.
post-13350827
Post #6,653 of 7,769
Dj Jaz
For some reason the IE800 fits in my ears perfect with whatever size ear adaptors they come installed with (medium?). I get perfect seal with no need to fiddle around.
post-13350846
Post #6,654 of 7,769
gerbi
Perth, Western Australia
  Remote controlling for iPhone/IE800?
Does anybody know a reasonable solution/adapter for controlling (volume, back/forward) the IE800 on an iPhone? Because I don't want to have to go to the players menu for doing this.
Sennheisers cable adapter RCS800 doesn't work fully with iPhones and costs $140, so this really doesn't make sense for me.
My ideal remote control adapter cable would accept the 2.5 mm jack and thus substitute Sennheisers 2.5->3.5mm adapter cable. But also a short additional adapter cable 3.5->3.5mm might be a consideration.
I have a Fiio in line remote/amp (no longer in production) that works quite well, but on their website they have this:
http://www.fiio.net/en/products/67
I hope it helps
post-13352957
Post #6,655 of 7,769
Silvano
Bolgheri (ITALY)
Bolgheri (ITALY)
Age
57
I wonder when the new IE800 will be released and whether the  balanced configuration will be implemented ,at least as an option.
post-13353032
Post #6,656 of 7,769
Dobrescu George
Bucharest, Romania
Bucharest, Romania
Age
25
Website
  I wonder when the new IE800 will be released and whether the  balance configuration will be implemented ,at least as an option.
You can theoretically use ie800 right now as balanced if you work out the cable configuration (the 2.5mm split is balanced from what I remember. )
post-13353092
Post #6,657 of 7,769
Silvano
Bolgheri (ITALY)
Bolgheri (ITALY)
Age
57
Mmmh.....I don't think so, actually the 2.5mm plug, connected to the earbuds , receive the two separate cables coming from them but it' s a TRS type, not TRRS,  which means the need to cut off this plug in order to get four separate lines to allow the TRRS configuration.....and it's just what I would avoid.
post-13353108
Post #6,658 of 7,769
Silvano
Bolgheri (ITALY)
Bolgheri (ITALY)
Age
57
Some time ago I wrote to Sennheiser germany asking whether the balanced option would be taken in account for the new IEM flagship an the reply was  "most probably!"........so, cross fingers and wait a bit!
post-13353488
Post #6,659 of 7,769
jwbrent
California
California
I expect there to be an S version at some point, and it makes perfect sense it would incorporate improvements to the original design as well as offering a balanced connection. One only has to look at the HD800/800S experience to come to this conclusion.
post-13353750
Post #6,660 of 7,769
Riley Beale
I have just tried some old iems of mine I have not tried in years.  My old V-Moda Vibes.  I figured out that iems with shallow insertion do not work for my ears.  Would the ie800 be one for me to avoid then?  i am sure I would really like the sound, but the fit could be deal breaker.
Thank you
Riley
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
