Dobrescu George
Reviewer: AudiophileHeaven
Anyone here has heard the Sony MDR-Z1R bass compared to IE800? Planning to buy IE800 if the bass is comparable.
The bass is considerably better in quality, might be a tiny bit less in quantity/
Remote controlling for iPhone/IE800?
Does anybody know a reasonable solution/adapter for controlling (volume, back/forward) the IE800 on an iPhone? Because I don't want to have to go to the players menu for doing this.
Sennheisers cable adapter RCS800 doesn't work fully with iPhones and costs $140, so this really doesn't make sense for me.
My ideal remote control adapter cable would accept the 2.5 mm jack and thus substitute Sennheisers 2.5->3.5mm adapter cable. But also a short additional adapter cable 3.5->3.5mm might be a consideration.
Really nobody? Also not from China?
This one takes 3.5mm male.
Thanks a lot. Will try it.
But as it's very long in case added to the standard cable, I may need a short female 2.5 to male 3.5 adapter, or such a very short cable. Any idea?
I had tried this several months ago, but apparently the Sennheiser 2.5 mm plug is somehow not standard. At least it didn't fit at that time with a short female 2.5 to male 3.5 adapter cable. Can anyone confirm this?
I had used this adapter, with Noble's bluetooth clip. Though it's TRRS, both channels worked fine.
I recommend this TRS adapter, to be on the safe side.
The 3 size mandarines and the medium senn. Keep in mind that the mandarines do not shrink as the senns due to the inner foam.
In case anybody is interested: I had ordered the MandarinES for curiosity and got them today.
In short: total desaster, don't even think of trying them.
They seem to fit well onto the IE800 nozzle, but there may be remaining leaks. The IE800 sounded completely out of balance, with nearly no bass. Only by keeping them manually and firmly pressed into the ears I got bass. But I could not find any self-stable fitting, with no size.
In comparison with the original Sennheiser ear tips, after careful testing which are best for the ear, I can get a very stable and repeatable fit, and with this fit, they also shield very well against outside noise. The same is true for well done IE800 ear tip clones. But those well done are not so easy identifiable from poor ones. I got them only after testing about 15 pairs from different vendors. Maybe better to "invest" the $15 (or so) for a pair of originals.
You should be a writer...
of sad stories...
@kuebler Are these the replicas or the real IE800? Maybe the bore sizes aren't the same.
You missed the bright horizon given in this sad story
I've done a lot of experiments in all directions, and I can tell you, that the Sennheiser ear tips are quite perfect: they shield very well against outside noise and they can give a perfect fit within the ears. BTW: I'm only talking about hearing sessions on the sofa. Walking around is a no go (no pun intended
The only thing you need to do is very thoroughly testing for each ear which size and form (round/oval) fits the ear for perfection. But perfection (or something close to it) you can gain.
