tracyca
- Nov 5, 2012
Thank you I'll give it try when I get home.
The first generation ie800 the entire cable was stiff, almost clothes hanger stiff. The next gen the cable only seems to stiffen on the upper left near the driver. The stiffness is problematic because it pushes up and can feel uncomfortable and possibly completely dislodge. There might be 3rd gen that does not have this problem at all. Might be more like finding a unicorn though..
Is there anything I can do to keep the tips from disconnecting? Or do I need to send them in for repair?
I just clean the the rubber eartips with dish liquid and water, then rinse and dry thoroughly. It cuts the oils from your skin that builds up over time which causes the tip to slide off. For the earpiece housing tip, I just use a dry cloth to wipe down the connecting ring that the rubber ear tip clicks onto.
Sorry, similar info was also given by Kulun
Okay so I ordered some IE800s off Amazon as a celebration of getting a massive raise.....
Here's what I get.
Wow Amazon.
What happened to quality control?
Sent from my iPhone using Tapatalk
WOW! You may have gotten ripped off!
THAT IS NOT AN IE800!!! (unless I am not aware of a completely new housing change?)
Did you receive yet?
Good job! Make sure everything goes though. I find this really alarming....the photos are blatently wrong and not even close to the original.
it is probably ie80?
