Dobrescu George
Reviewer: AudiophileHeaven
microphonics are not a terrible problem. i can love with them... the cable hardening are what i am afraid of.
This is all a conspiracy. The IEM has been out 18 months or so. 200 pages of posts....no cable issues. Then, all of the sudden in the past 3 weeks everyone that has ever owned or listened to the IE800....the cables just harden and split in your hands. Crazy ****.
The sound quality is not affected by the cable issue, but they become absolutely unusable. The cables are stiff like a piece of metal wire. If I turn my head slightly, they pop right out. I've been dealing with Craig at Whiplash Audio. He modifies the IE800s by removing all of the stock wire and patching his TWag or TWau cable straight into the speakers themselves. Someone posted a picture of one that they found on Ebay. So you get the best of both worlds. You can pick which one of his wires you want, you can have it terminated in the plug of your choosing and you will never have to worry about the cable hardening issue. Also you won't have to deal with that stupid 2.5mm heavy connector that Sennheiser decided to include in the middle of the cable for some weird reason. I will post some pictures when I get mine back in a week or so.
Is there anything I can do to keep the tips from disconnecting? Or do I need to send them in for repair?
Does both the cables get stiff? The bottom cable and the cable attached to the earphones?
