lee730
- Jan 9, 2011
Is it up there with your Sony now? So I'm guessing your silver plated cable has less treble than your stock cable? Wow my silver cable (it is silver cable BTW I confirmed it with the owner; the seller who claimed it to be silver plated worded the add wrong and the owner made him change it to silver cable, not silver plated). That is one reason to buy from China because the prices are generally cheaper and you can still get quality products depending on where you buy.
You were right. The sibilance has disappeared completely. This cable makes the stock ones sound treble happy now. The bass has calmed down quite a bit with the new cable. I don't sense the mid bass hump. Sounds really balanced. I used the ZO to test my hearing. With the stock cable, I have to have the ZO set all the way down and there's still plenty of bass. With the custom cable, I can turn to ZO up a couple of notches to get the bass I like and it doesn't sound boomy. Really good investment to improve the sound quality of the IE8.
