Rob80b
No it is not an easy procedure, the connectors require to be heated and then twisted to unscrew them apart and the pieces are tiny, fun soldering and putting them back together! Also as the cables are rather well made one has to remove quite a few layers.Is there any particular technique to pull out connectors easily, or is it always that hard?
Here in Canada I contacted Sennheiser, the 1st one was sent in under the 2 year warranty in 2018....thought maybe it was just an anomaly, then the 2nd, same thing. Searching on line I discovered this was a rather common occurrence and sent that info to Sennheiser who then sent me a 3rd. When that one went last summer I basically gave up but contacted them anyway and then picked up the 3rd party cable. Then recently out of the blue I was unexpectadly sent a 4th one, apparently there was a parts shortage on most parts for almost a year, I will keep it unopened. : )So, you contacted Sennheiser directly about the cable issue, not the vendor?
Not really...but we can only assume it is the natural rubber used and interacting with some individual body oils, as this never happened with any other headphone cables, I've one HD650 cable going on 10 years or more.That's weird, oils?
