Any particular reason to replace the stock, too long, too bulky, unmanageable, deteriorated like mine did....????
I wouldn't spend silly money though.
Thanks! No, it's all fine. I like stock cables a lot. I got three with HD 820 - made in Germany : )), and I got two (only) with HD 800s - made in Ireland : )).
I now have four that I don't use. Two 4.4 mm and two 6.3 mm. I use one XLR, and I "need" one more XLR. No, I don't actually need one; I already bought one XLR on Amazon, it was a good price, and it looks like it fits with the amp (Auris HA-2 SF) as it came together. It has wooden parts, just like the amp. So basically, I like this one a lot.
4 pin XLR
I thought I might buy one more XLR if I find some good responses from those who claim it's better than the original, but also, I am not willing to pay a lot. These you posted could be in the range I would be willing to pay.
But also there is an option of Aliexpress. I bought some cables there, and it seems that it was worth it. I did notice a difference (I replaced the original VDH D-102 MK III with Aliexpress Nordost Odin), especially with my cheaper set-up AMP/DAC. I combined cables now differently, and I like the sound better. With Auris, anyway, everything seems perfect, so I couldn't tell if there was a difference...let's say the placebo was active, and I did think, hmm...this is now a bit better too : )
BTW: I was reading about other cables and some claim that LAN cables make a huge difference, especially those CAT8. Do you think It's worth buying one and replacing the existing one which is... actually, I have no idea, it's a basic grey one : )?
Cheers!
