Rob80b
Was recommended to post my user experiences. Since owning my HD800S since 2016 I've had 3 CH800 balanced cables disintegrate and is a known issue with more than a few dozen reported cases (can supply if requested).
Believe it has to do with body oils breaking down the rubber used on the 800/800S cables as I've never had this happen with any previous Sennheisers or other headphones.
Each time Sennheiser was kind enough to replace each cable, and I'm now on my 4th.
The other issue that could also maybe be addressed are the Alcantara pads, after going through 3 pairs which also eventually disintegrate and shed everywhere, I've adopted lambskin as an alternative.
My HD800S have been used on regular bases since 2016 and except for the pads, ear and headband and the cable they have overall held up very well and still sound great.
CH800 Paracord and leather pads. : )
One simple solution Sennheiser could do and save a lot of headaches and what I did with the previous deteriorating CH800 cables was adding some para-cord to the exposed rubber sections. I recycled one with exactly that for use with my HD660S2.The 1st to go was in 2018
2nd 2021
Most are reporting no problems at all, mind you I use mine almost daily except until recently as I've been using the AKG K872 and Focal Elgia on a rotating basis. And just the other day I was convinced they really did change the composition in the rubber, must have jinxed it....Oddly it is always the left side????
Got my HD800S just after they were available and have been through 5 or 6 pairs of pads so far since, same for my Urbanites which have a similar material .... the velour on the 6XX's do not do this, they just get flattened.
