Whazzzup
Rca is se output to a balanced amp is not topographically utilizing the amp. Doesn’t mean it doesn’t sound fine. An adapter defeats the balanced out put. I mean true end to end balanced from power through to hp.
True end to end balanced is indeed ideal, though the HDVA 600 is more than a mere passive adapter. All unbalanced (SE) inputs are converted to balanced at input, and then are balanced through all the amplification stages.
In fact, many source components with balanced outputs don't really have balanced circuitry throughout the entire output stage but invert the signal just before the xlr jack. It's really the same thing the HDVA 600 does. In one case it's done in the source and in the other it's done in the amp.True end to end balanced is indeed ideal, though the HDVA 600 is more than a mere passive adapter. All unbalanced (SE) inputs are converted to balanced at input, and then are balanced through all the amplification stages.
try to use the 'thumbnail' option when uploading pictures, so others can see your image in one go.I use parametric 3 bands for hd800s.
Feel it better.
1st. 5dB @30Hz Q0.6
2nd. 2.5dB@90Hz Q0.4
3rd. 2.5dB@750Hz Q1.0
All are peak band filter
Describle : 1st and 2nd in total is a smooth curve from low end to 500Hz, what ever the gain but keep 2/1 ratio (above +5 and +2.5).
3rd is for vocal to be bolder a bit.
Dap is AK sp1000, it respond not much as usuall. I think it is as half, if set +6 it acts like +3.
Can someone recommend the very best 6.5 to 3.5 adaptor for a senn hd800s with the mojo? i'm considering the hd820 to use with my mojo. how is everyone connecting their hd800s to mojo as i understand it ships with only the 6.5 jack? thanks mk. is sq affected by adaptors.
I have not heard the Ragnarok but the Sennheiser HDVD800 really fleshes out the sound a lot compared to the other amps I have. It goes for $1500.00 these days on Amazon. I should add that I use it as an amp only so can't really comment on how the dac sounds.My ears are not big fans of the sound coming through Gumby, Jot, and balanced 800S. The separation, air, and perhaps most of all comfort are nice but the sound is a little thin, dry, female vocals are inferior to a single-ended LCD-X and to my ears there is a tonal imbalance that results in discomfort and ear ringing, i.e. that's bad. I can't get either the comfort or soundstage from the LCD-X so I'm considering giving the 800S a second chance. Will the Schiit Ragnarok give the 800S full, substantial sound with great female vocals while keeping brightness under control? Is there any amp without five tubes that are the size of limbs at $1500 or under that will do this?
Auralic Taurus MK2My ears are not big fans of the sound coming through Gumby, Jot, and balanced 800S. The separation, air, and perhaps most of all comfort are nice but the sound is a little thin, dry, female vocals are inferior to a single-ended LCD-X and to my ears there is a tonal imbalance that results in discomfort and ear ringing, i.e. that's bad. I can't get either the comfort or soundstage from the LCD-X so I'm considering giving the 800S a second chance. Will the Schiit Ragnarok give the 800S full, substantial sound with great female vocals while keeping brightness under control? Is there any amp without five tubes that are the size of limbs at $1500 or under that will do this?
