Sennheiser HD650 & Massdrop HD6XX Impressions Thread
Oct 3, 2015 at 3:19 PM Post #29,476 of 46,514
Question. I don't know what the H5 is but I love the stock ones. Very comfy. Why not stick with the Sennheiser earpads?. Thx
HM5 pads are by Brainwavz and considerably less expensive than the stock pads. I think that the stock pads are about $40 from Sennheiser. I got the hm5 pads for $5 and a few bucks shipping. It's early but I think I may like them at least as much as stock pads.
Oct 3, 2015 at 4:05 PM Post #29,479 of 46,514
Great job of getting them on Matt.
They look like they were made for the HD650.
I spy an Either in that pic
Oct 3, 2015 at 4:30 PM Post #29,480 of 46,514
^^Thanks. The new pads are a little "chunky" compared to the stock pads, but I'm kind of liking them right now. Even if they were the same price as stocks pads, I might take the hm5 pads. It's a little early though. I need more time with them.
Oct 3, 2015 at 5:14 PM Post #29,481 of 46,514
Looks like Grado Prestige Series foam.
But for $5 what have you got to lose by trying them out, the factory ones are going to wear out sooner of later.
I live in FL and sweat a lot in mine so I suspect sooner. I may grab a pair just as a backup, never know when mine might split open from sweat rot.
HUMM,   Just looked, they ani't $5, they're $20.00 or more depending.
Oct 3, 2015 at 5:23 PM Post #29,483 of 46,514
Matt, Where'd you get em for $5?
TIA
OPP, You beat me with the answer LOL
Oct 3, 2015 at 6:46 PM Post #29,485 of 46,514
Oct 4, 2015 at 3:14 AM Post #29,486 of 46,514
Oct 4, 2015 at 6:57 AM Post #29,487 of 46,514
if comfort was an issue I would be rushing on those thick pads. but on the hd650 it's not IMO. so I'm not sure I'm willing to go change the sound for no serious reason, I spent too much time on my EQs ^_^.
still it's nice to know that they fit.
Oct 4, 2015 at 8:15 AM Post #29,489 of 46,514
When I first put them on with the hm5 pads, the clamp was a bit stronger because the pads are thicker. But after just a few minutes the memory foam adjust to the shape of your head and feels very comfortable.
Regarding the sound change, I didn't want to mess with the sound of the stock 650 either. This was mostly just an experiment but now I'm not sure that I could go back to stock pads.
