Anyway, back on to the HD-650...
One of my cats chewed up the stock cable (along with my Grado cable, which I sent in for re-cabling some time back). Yes, I thought about hanging the cat with what's left of the cable, but my daughter would be unhappy.
Then, based on a recommendation from a fellow Head-Fi'er I purchased a cable from Venus Audio (which I think is a guy in Wisconsin, US, that builds and sells cables on eBay). The Venus Audio cable is fine - was inexpensive, nice build quality, looks OK. But, it has a heat-shrink sleeve on the 'phones-side that is very stiff. Whenever I move my head, the sleeve rubs against my shirt collar or a zipper on my sweater and makes fairly loud sounds within the 'phones.
My problem with the Senn stock cable is its length - I have to worry about the slack or, again, the cats start chewing on anything that dangles even if I am sitting there. I suppose I could coil up a replacement with velcro... but...I am soliciting recommendations on a 650 cable that is:
1. Short-ish (maybe 1 - 1.5 M)
2. Supple (soft cable and sleeve)
3. Reasonable build quality and looks nice (i.e. I like audiophool bling)
4. Not more expensive than the headphones themselves...
Thanks, in advance.
