Originally Posted by zeplin
Is the shape you chose for the 600/650 a specified shape that could not be changed if requested?
I am not against trying something different and if I like it, that could be the new norm. Quote:
And if you have to screw in the woodies to the frame with the 4 screws, does that mean they can be unscrewed to take off the woody cups in order to put the metal grill back on, and then re-used again another day? If so, how many times could a person do this before the wear and tear of the screw holes kicks in? |
They will stay in somewhat without the screws but if they fall out, you'd want to have carpet or cushioned furniture around. Since existing holes in the Senn frame are used (I wonder what Senn had in mind for these since they are in the right spot for a closed cup design), the screens can be put back on and off since there is basically no modifications, with the exception of the holes getting a little larger (unseen area under pads). Depending on the wood type and if you didn't overtighten, you could reuse them many times. Holes can always be refurbished with say, wood glue and toothpicks anyway. Quote:
I also am wondering a great deal about how the HD650 would benefit from this major modification? I know you said you haven't done it yet, but is there any chance of you letting us know when you do? If so, what would be your rough estimate as to when you would be able to woody out the 650's? |
Maybe someone at the Seattle meet will have 650's that we can slip them on, otherwise, I'll just have to wait till I get some personally. No reason it couldn't be done now as far as I'm concerned, just need a guinea pig. What the outcome will be is unknown for now. Quote:
Although, at the same time, I don't know if I would really want to change anything about my beloved HD-650's as they are pretty much perfect in my eyes. So this is where the "is it permanent" question of mine kicks in. |
Perfect is, until there is better... these are aimed at 580-600's though they'd sure look nice on 650's, soundwise, unknown for now. As we all know but may not admit, you simply don't know till you try something for yourself, what the benefits/downfalls are. At some point, there will probably be a set of demo cups floating around for peeps to try, just not quite yet.
BTW, Thanx for contributing to head-fi so much as you have done a good job with re-kindling old relationships with people's older headphones that they thought they knew. This modification hobby of yours has clearly opened up a whole new arena for us headphone lovers. |
Thanks for the kind words and I enjoy looking at something in a different light, a little out of the box, and seeing where it leads
