I would agree that the HD 700 is amp dependent. It’s also not tuned neutral or with the typical “Sennheiser Mids...” The design concept was:I have an R70x. Is it worth upgrading to the HD700s or should I jump straight to the HD800's or HD660S? Also, why does everyone hate the HD700s (like Z Reviews)?
•a more affordable HD 800
•with more bass
•a smaller size
•and easier to drive with 150 Ω at 1kHz
•a more standard cable attachment (2.5mm into the earcups).
So, while it is easier to drive than the 300 Ω HD 800, and actually does fairly well from the balanced port of my Sony ZX300, it’s not quite as easy as a typical portable headphone with 32 Ω resistance and 110 dB sensitivity. Amping quantity and quality is also a factor: people try connecting it straight to a laptop’s built-in headphone jack or something else that is powerful enough to make it loud but not quality enough to show the full resolution and control possible with the headphone.
Lastly, it’s an intentionally colored sounding tuning. For some, that’s a lot of fun and heightens their emotional enjoyment, but for others it sounds “wrong” and not what they were expecting at its price point. Since personal preference plays a stronger part in the perception of this headphone, it ended up being pretty divisive.
I perceive it as a headphone with fairly warm midbass and lower mids, but the main part of the midrange is a little recessed, and the treble was a bit more sparkly than average. Note decay was pretty fast, which gave notes decent “snap” and contrast, though not as well controlled as the HD 800 (and the HD 800’s bigger driver displaces more air). It had a fairly “big” soundstage size as well, no doubt “helped” by the angled drivers. The headphone was lighter than average, the headband was thickly-padded but there was no gap at the apex of the headband like the HD 650 and HD 800S, and the earcups were completely circumarual with above average space to leave ears untouched inside.
The HD 660S has more forward mids and more body to the sound (HD 700 sounded thinner in the mids), while still having strong note separation and fast decay, flat drivers and thicker pads. There is a lot more discussion on the HD 660S sound on that headphone’s discussion thread! https://www.head-fi.org/posts/15717620/
I tried to give a description without injecting my preferences; hopefully this helps you make up your own mind. Cheers!
