I dropped them last night. So sad to see them laying on the floor like that. Anyway, one of the ear cups popped off and it gave me a heart attack. None of the plastic tabs were broken or anything, and I managed to gently reattach the ear cup, although I didn't really now what I was doing. I just laid it in place and gently turned it and it just went back in. Seems fine. Anyway, glad they still work. God I hate dropping my special gear like that. I'm not liking that they dropped. Are these fairly durable in your experience? I'm a little paranoid that the drivers might have been tweaked or something although they sound fine so far. Also, these are currently going for a great price on Amazon for $420.
So far I'm 3 for 3. My 700's are connected to my Valhalla 2/Bifrost sitting on my kitchen table repurposed into my computer center. If they're not on my head, the 700's hang over the back of one of the chairs. I've knocked them off the chair and onto the carpeted floor once and twice the cable got snagged between my leg and the table, snapping the headphones out of my hands and onto the floor. All three times one or both of the cups have come off, but was able to snap them back in place no worse for wear. I'm thinking I'm wearing out my luck and the third time really was the charm, so I'm trying to be damned careful now! Since they are only plastic not designed for extensive use you (and I) shouldn't make it a habit!
Thanks, I have to say it sounds so good with the HD 700(even without burn in) there are some sounds that I have heard before in songs, I guess due to the sounds being amplified.
Might be electronic interference, however when nothing is being played there is a static sound. It is constant and changes volume (static) when I turn down the AMP and turn up the OS based volume, it is not as loud. Getting the DAC next month, however I will get an extension which filters the interference
Might be electronic interference, however when nothing is being played there is a static sound. It is not constant and changes volume (static) when I turn down the AMP and turn up the OS based volume, it is not as loud. Getting the DAC next month, however I will get an extension which filters the interference
I always have the OS volume at max. I would guess your getting some interference from the computer power supply or some other component inside. A dac will likely cut that down .
Just noticed I open up a game and the static is constant and quite loud (on desktop it is not constant, most of the time you cannot hear it) will order an extension filter plug
I just heard the HD800 and HD800S for the first time ever. Listened for about an hour or so and my oh my are they a treat. Connected to an Audiolab M-One, the soundstage is better and the overall sound more coherent then the HD700 on my setup. But who knows, maybe the M-One is the main difference maker here )
