Hifihedgehog
- Oct 24, 2007
That's stretching the definition of the the equal-loudness curves though: it's just what the ear interprets as equal relative to sound level. It's not used in headphone design as far as I know. When you record music, there's no equal-loudness curve applied: it's just whatever the audio engineer deems may add for taste. So no, equating headphone response with equal-loudness curve and concluding it's neutral
However, yes, you're right: not HRTF, diffuse (or free) field equalizations is what I meant. They're the target response back then, but a few target responses have popped up, all of which don't incorporate the equal-loudness curves. The equal-loudness curves are present even if you're using a speaker or listening to an orchestra: it's not something that's to be corrected.
Equal-loudness curves can be used in any sound device to remedy the perception of sound response at lower volumes, and it is easy to see them being incorporated in the frequency responses of modern diffuse-field equalized headphones--that is the point. Tyll at InnerFidelity referenced its possible use in the Shure SRH-1540, but I believe it is also being more widely than that, by Sennheiser in their latest high-end headphones, by Philips in the Fidelio X2, and many, many others. Headphones in the past have relied on dead neutrality, such as the Sennheiser HD 600, which was designed to follow industry standard diffuse field equalization as closely as possible. Saying none of the newer variations of diffuse field equalization incorporate it is a misnomer because diffuse equalization has stayed relatively the same as a standard while manufacturers are compensating for something other than measured neutrality in their headphones' individual frequency responses. The problem is this unmodified diffuse field equalization does not work for listening pleasure at safe, normal listening levels, since at volumes lower than 120 dB, the level of bass and treble compared to midrange is perceived as compromised, and this is only exacerbated by headphones which lack the dimensional clarity and physical impact of speakers.
Now, it is very easy to see something uncannily reminiscent of equal-loudness contours in the sound responses of more and more modern headphones and the fact that many high-end manufacturers are tending toward this tuning makes sense. One prime example of this is the Harman Target Response Curve, of which Tyll at InnerFidelity is a huge proponent who believes it is the next big thing in the industry. In his descriptions of it, it is revealed that it was not developed to further the technical accuracy of diffuse field equalization but its primary objective was to find the most favored sound based on user feedback of pleasure for given modifications in frequency response. The optimal or most pleasureable curve is shown to have boosts in bass and treble which are located very, very closely to the same places that an equal-loudness contour would have them. Coincidence? I think not. Also, to correct what you said, an equal-loudness curve is not applied automagically just by playing back a recording, as it is an equalization technique which has to be consciously performed to simulate full loudness at volumes lower than 120 dB. One way equal-loudness curves have been applied in the past is through the loudness button, and there is a now trend to incorporate this through the mechanical tuning of headphones as well. To conclude, as I explained earlier, there is absolutely no reason why anyone cannot incorporate this curve in diffuse field equalized headphones. And from what can be seen, many manufacturers already gone ahead and done just that in the new target responses of their headphones.
