@Midgetguy, for comfort its hard to beat HD-700 and HD-800, wish more manufactures would shape ear cups like the shape of the human ear or a least like the Senns
Sennheiser HD 600 Impressions Thread
- Thread starter Windsor
Midgetguy
How similar in comfort are the HD800s to the HD700s? Cuz I did get to use the HD700s for a bit. While the HD600s are lighter and I think I like the padding on them better, the cupping and shape felt better on the HD700. The cups seemed to be d-shaped which felt very natural.
I want more manufacturers to at least make oval openings, even if they don't abandon the circular outer shape. Basically, for earpads and earcup shape, I think Sennheiser is king. Their designs just make natural sense. To date, my top 3 most comfortable headphones that I've tried are the HD700, then HD600, then the Hifiman HE1K for the sake of not having another Sennheiser on the list
I'd say the HD-700 are a little more comfortable than the HD-800 only because the HD-800 clamping force is too light and there is more weight on the top of the headband. The only problem with the HD-600/650 is the pads can be a bit to shallow for some and some times the initial clamping force is like a vice grip but easily fixed. Beyer's aren't too bad either, my T1 and DT-990 premium are fairly comfortable, much lighter clamping force than HD-6XX.
Midgetguy
I think that the pads of the HD600 is thick enough, but that the interior space of the cups are smaller than the HD700. Makes the HD700 very spacious for your ears and that's a definitely plus for comfort.
Kodachrome2000
- May 10, 2011
what does the burson soloist do to these headphones? i've seen a couple short impressions, but nothing that i felt really conveyed a lot of info.
yangian
- Sep 22, 2014
http://www.head-fi.org/t/643884/burson-soloist-with-hd600
Kodachrome2000
- May 10, 2011
yeeeup; that's actually what got me started trying to hunt down other reviews of the combination. while there was a small amount of info, it was from a couple people who were banned under different names. for all i know, it could've been the same person talking to themselves the whole thread.
also read all the little 1-2 line reviews on the burson website, as well as general burson reviews.
yangian
- Sep 22, 2014
yeeeup; that's actually what got me started trying to hunt down other reviews of the combination. while there was a small amount of info, it was from a couple people who were banned under different names. for all i know, it could've been the same person talking to themselves the whole thread.was hoping for something a little more fruitful or trustworthy? didn't really seem to turn up much of anything else.
With 4W per channel, this is a powerful amp. and it is said in the similar tier as Elise.
RamblerBoy
- Dec 24, 2011
i just got my hd600 today and i am running it right off my laptop without any amp and i am getting decent volume levels at around 35/100. is an amp really needed for this?
- Jan 30, 2011
Impossible to know without you laptop specs. But they do improve quiet a bit with a decent amp behind them. I've been testing the VE Enterprise with the HD600 and I've been amazed at the additional improvement over some of my other sources.
RamblerBoy
- Dec 24, 2011
thank you brooko. guess i will try some amp out to know for sure.
is the output power of chord mojo enough to bring the best out of these headphones? i have read reviews/impressions claiming mojo to complement hd600/650 really well but just to be sure.
- Jan 30, 2011
Should be more than enough. it'll put 35 mW into 600 ohms, and the HD600 is only half of that. Would be a pretty good pairing I'd imagine. If you want another option - look at the iFi Micro iDSD.
RamblerBoy
- Dec 24, 2011
@Brooko thank you so much. i will look into that too.
ch1n4
- Oct 21, 2011
Hi Brooko, I am also looking for a decent amp for my new HD600. This VE Enterprise you are talking about, what is exactly, DAC/AMP or DAC only? Couldn't find anything about it...
earl grey
- Apr 4, 2015
Also looking for an amp. At this point I am using the HA-2 with the HD-600 and am very happy but wondering if things can get even better with a desktop. Would love to hear from those who have experience with this. BH Crack seems to have quite a following would love to hear more from others to get a sense of the top amps for the HD-600. Thanks.
Total: 26 (members: 0, guests: 26)
