Midgetguy
Good for you then. My HD600 arrives tomorrow and I can't wait to meet an old friend.
Amazing to think that this brilliant headphone has been on the market almost as long as I've been alive. Old friend indeed.
I have tried a number of the HD580/600 mods in years past such as
--quarter hole in the inner foam earpad discs
--total removal of inner foam earpad discs
--Blu-Tac damping of various amounts/degrees/locations
--various sized felt inserts between grills and back of drivers
--felt layer on top of inner foam earpad discs
In each case whatever positives they were supposed to bring, there were negative trade offs such that I invariably returned my cans to stock.
BTW the spyder trimming/removal mod is one I didn't try because, like you, I eschew any mod that can't be reversed.
Hey guys. Finally jumping back into 'phones.
i REALLY enjoyed my hd598. i understand the soundstage on those dwarfs the 600, and that worries me a bit. i loved feeling immersed in the music - i need my amp to give me as wide a soundstage available.
other than that, as long as the sound can remain as neutral as possible, which is what these cans are famous for, and the amp gives me the headroom to get some bass slam i'll be happy. i plan on using EQ because every once in a while i let my basshead out - i just want enough power from the amp to give the headphone good control and impact into the depths.
thanks for any insight you might have!
So far I've had a few pairs - monster turbine coppers, hd598, fischer audio fa-011, and a couple others i can't really remember - klipsch, sony, etc.
I decided to pounce on the gift card bundle from amazon last night (hopefully their one day shipping holds true - it's supposed to arrive tomorrow but nothing's been updated yet) and i know that for the first time in my headphone listening experience i'm gonna need an amp. i'm brand new to all this despite having read gobs of information here on the site.
i'm not too concerned about budget - call it 1000$ tops. i've read over 100 pages of this thread and was hoping to get some recommendations based on my preferences. so far the suggestions all seem concerned about getting absolute bang for buck on an amp/dac, and that is not what i'm concerned about.
i'll be getting a dac secondarily, with about the same budget for that component, preferably under 1000$. it's my understanding that a DAC doesn't really color the sound an amp can. correct? so it may not really be worth spending a lot on this item.
i just want to start with a really classic, solid headphone for decent money - i'm not going to take parts of my budget for amp/dac and use it to get a different headphone. if i get the itch to upgrade, i'd like to be able to swap to most headphones without too much hassle about synergy - so a decent allrounder amp and dac are a must. maybe i'm wishing for something that doesn't exist; i don't know! it seems there's a lot of talk about sound coloration.
i might even be tempted to do something CRRRRAZY, like buy something so i can upgrade to a balanced setup later for kicks.
This is slightly concerning as my understanding is not that the sound of the HD600 is neutral, but rather that it is very natural. Those are two different things. Of the headphones I've listened to in this price range, something like the AKG K7 series is better in terms of looking for neutrality. The AKGs also have a larger sound stage. But I prefer the HD600s because the sound stage is still a decent size (average maybe? Depends on your scale of reference) and the tone sounds more natural. Also important is a headphone's ability to image well and place instruments accurately, which the HD600 does incredibly well at.
I'm sort of in the same position...just getting back into headphones as it seems my speaker setup will be retired for the foreseeable future. You are right about needing an amp....you might also need to EQ. Here's a current thread you may find helpful. Made a huge difference in my case. I'm using a Fiio E12 as an amp for the time being.
http://www.head-fi.org/t/797907/hd600-my-custom-bass-extension-curves
Happy listening!
Bern
Originally Posted by Kodachrome2000 /img/forum/go_quote.gif
Thanks for the info! Being that I haven't tried a whole ton of headphones I figured the 600 would be a safe jumping off point into real gear, and you're correct - i haven't really memorized the list of terms on the site so i should probably be a little more careful with what i say, haha. i do prefer a natural sounding headphone, but i had read that these are a good mix of natural/neutral, correct? i thought that's why they are so popular and considered as such a good all-rounder. i just don't want the amp/dac to tip it too far so that it would be considered lush like my 598, and i also don't want it to be perfectly neutral and flat. i'm probably worrying about nothing, especially considering i haven't even heard the 600 yet! it may be wiser to listen tomorrow and then nitpick. i'm just on the edge of my seat waiting for tomorrow.
as long as there is good placement and i can point out instruments i'm sure i'll be happy. my concern about making the soundstage as large as possible - obviously i can't buy one headphone and make it sound like another, but i do also play videogames and i love wearing headphones while doing so to feel fully immersed in a world. the hd598 was great at this.
i can't imagine being unhappy regardless. really what i'm looking for is an amp to open the soundstage as much as possible, keep things on the neutral side of natural - i don't want to be quite so enveloped in mids as the 598 - and give me some good bass that i can crank on, even though i know it won't be a bass monster by any means.
perhaps my requirements are just too vague since i don't have a clear sense of direction without listening. i overthink things quite frequently. probably best to just wait and give it a listen - thanks for responding though!
I use my HD600's with the Valhalla 2 and couldn't be happier. Just remember that these phone require voltage more than current and that is where the OTL tube amps like the Valhalla 2 and the BH crack really shine. They do not fare so well with low impedance headphones like Audeze or hifi man headphones. If you want an amp that would be more versatile for more types of headphones you might want to look at the lyre 2.
