perhapss
The obvious answer is to do both.
I`ve never subscribed to equalization ....
Maverick Audio Tube Magic D1 Plus.
Listening to Weezer now. Sounds a treat.
I just bought the HD 600 and I have Asus xonar essence stx, the sound is good. Will the sound be better if I buy an amp? If so which amp should I buy?
Does it play loudly without distortion? Same for bass.
Do loud piano notes play without distortion on the peaks/attacks? Same for other similar instruments with sharp attacks.
Do you like iits sound?
Answer these questions and you'll probably have an answer about should you "buy another amp".
I personally think that the issue with sound cards usually isn't the amp half, but the DAC half, at least for most headphones out there. Some are pretty power demanding, but most, HD600 included, can be run fine from the amp on a sound card. DAC though, that's a different matter...
And in case others were wondering, I'm using a Topping D20 for my DAC and a Topping TP30mkII for my amp.
You definitely should buy THE MOST EXPENSIVE tube amp available to man.
Especially if the brand sponsors important audiophile magazines.
