Thanks, I think I am seeing similar prices for the used market here too.
Thanks, I will not like to use Facebook though unfortunately
Thanks, I am actually looking at Singapore (where I am at), UK and Germany Amazon but they are not sold there. I will look at US Amazon during its Black Friday then. And yes, I am actually trying to get a new pair at the usual used prices. I do recall seeing similar sales at the local audio shops too but wasn't ready for it back then
Thanks, this is a good idea. Right now it seems that Amazon.ca won't ship the HD600 to Singapore, but it may be able to get me certain things at a better deal than Amazon US
I randomly took off the foam that's protecting the inner side of the drivers on my HD600 just to quickly compare the Dekoni with the stock pads and I think the result is really interesting. There's a better sense of transparency and immediacy to the sound, as if some kind of veil was removed. It sounds a bit cliché but I think it is real. I put the foams back in place to confirm my impressions. The tonality is also a bit brighter but I think this works well with the fenestrated leather pads that still tame the top end. The result is a nicely dynamic and sharp headphone that still rocks.
No question that removing the foam results in a clearer more transparent sound. Put some dynamat and felt on the backside (careful not to block any channels from the front), and you get a taut and clear bass to match, with a bit less delayed treble. Then get an EQ on it to even it up:
88 hz 3.8 db .071 Q Low Shelf
160 hz -2.1 db 1.10 Q dig bell 2
2500 hz 1.0 db 2.30 Q "
3850 hz -3.3 db 3.33 Q "
8000 hz -4.0 db 3.33 Q "
12400 hz 4.5 3.90 Q "
Very few headphones need no correction between 250 Hz and 2 kHz. Any fan of the 600 that hasn't heard them on a OTL amp is missing out.
I’ve tried playing around with the front foam on all the Sennie 6 series cans that I’ve owned. The one that I feel ends up sounding the best is actually the HD58X via the curtain mod.
I didn’t particularly care for the added brightness over my 600 compared to my friend who almost exclusively listens to Sennheisers with the front foam removed...he also really digs the new HD560S, which in fact is a brilliant rec for 600 owners wanting that extra bit of zing up top whilst adding an impressive bass performance.
I’ve actually never tried anything mod-wise with the 600 that ended up improving on the stock sound but yeah...tastebuds
As for pads I always stay with stock. The only ones I’ve tried that didn’t ruin the sound were some Yaxi pads. I still recommend stock though.
^ A modest amount of mass damping on the backside via dynamat increases speed and nimbleness of the 600 bass, which also removes the trace of chestiness/veil in the lower mids - but it does decrease total amount of bass - not for rock fans but classical/jazz/great recording fans should be happy. I listen to rock too, so its either go to the HFM 500/6se or increase the EQ for the bass of the 600, or change from SS amp to a OTL.
I have been enjoying immensely the HD-600s with three modifications. One is the CNC copper ring system from Custom Cans (U.K.) for the "mass damping" . The next is the replacement of both ear-side foams with Chicopee Chix 8311 dry reusable wipes. These are quite thin and are well perforated, allowing the sound to come through unimpeded. (Clearly, this was not the intended use of Chix by the company; I was opening a new box and I thought "what if..?"). To my ears, your description of increased speed and nimbleness of bass is spot-on. I have not gotten the impression, though, of a decrease in total bass - maybe a lesser emphasis on bass (due to lower frame resonance from the CNC rings?). I think that the mass damping also mitigates peakiness in the upper registers. Those, I feel, are more open and convey more ambiance with the replacement of the ear-side foam. Lastly, the Dekoni Fenestrated Sheepskin earpads for airiness of sound and for comfort (the stock velour pads are good...just wanted to go 'full monty'). The HD-600s, in this mode, are my go-to headphone for outright music listening for appreciation and enjoyment.
Yes, they are interesting and CC is a good outfit that has been working with Senn's for years. Haven't tried myself.
Interesting. I use the rear dust blocking material from round form HFM's. Seems much better, but no idea vs your solution.
My 600's make my 4 can rotation - on the BHC. The other 3 on the Rag 1 (HE-6se, HE-500, HEX v2). Like to get a nice used 800 to run on the BHC, before I snag the Susvara fingers_crossed:).
[/QUOTE]
Ive had my HD600 for about a month and theyre going to be one of my forever phones. At the time they were used alongside my EMU Teak and they both complemented each other well. (Teak being the v-shaped fun phone and the HD600 being the relaxing/singalong phone). Since then my Aurorus Borealis has replaced my EMU teak but I plan to keep the HD600. They’re built well and I can easily find spare parts for them if I needed to. I can’t believe Sennheiser made this phone some time ago and it has aged well.
All I know is that the cheapest way to headphone nirvana is a used Bottlehead Crack w/ speedball
and a used or existing HD-600. Both obtainable for as low as $550 total. Beat that.
Sold my HD 600's back in April, and been kinda regretting it, so looked on this thread thinking of finding another pair. When did they change the color to black??? Do they still sound the same as the marbled models?
